Old 06-19-2019, 10:32 AM   #1
Black Tank Odor Question
We purchased our Windjammer 2 years ago. We had a Wilderness trailer for 9 years before. Weíve always used Happy Camper tank treatment and never had odor in the Wilderness. In the Windjammer, the bathroom starts smelling when the black tank gets full. The odor goes away after dumping.
I assume the odor is coming through the roof vent, which is close to the black tank vent on the roof. Why would it only smell when itís full? I assume that odors are always escaping the blank tank vent, full or not. Also, shouldnít the bathroomís vent fan push the odor out and prevent it from entering through the vent?
Not a huge problem, but just donít know why it stinks when itís full.
dankirk is offline   Reply With Quote
Old 06-19-2019, 11:28 AM   #2
When full more "stuff" decomposing causing stink.
I'd check the roof vent to make sure it's really clear. Could also be that vent is extended too far into tank and when full it's closed off with the "stuff" in your tank which leaves the flush valve as the only outlet for gases causing the odor.
Could be also time to explore a different tank chemical. I use Odorlos and find it works (at least for me) better than any of the numerous other chemicals I've used over the last 40+ years.
As for determining whether or not the vent is extended too far into the tank, it may be necessary to have someone look inside with a flexible "borescope" after you've dumped and rinsed well.
If it's a matter of odor coming through the roof vent, sometimes a vent cap that swivels in the wind and only discharges odor downwind helps. Discharging in the direction the breeze is blowing will help disperse the odor more quickly.
Back to chemicals. Some just try to mask the odor with a strong scent. Others work to keep the breakdown to a minimum so more odors aren't released. Some even try to help the "sewage" break down more quickly and also mask the new odor with their own fragrance. Big thing is to make sure you have good vent flow.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
Old 06-24-2019, 08:45 AM   #3
GeoPro Owner
bsinc1962's Avatar
One thought on this as I've experienced something similar on my GeoPro. If running the vent fan with all the windows and door closed the draw on the exhaust fan is so strong that the only place to draw air in from is through the sink drain or shower drain. As soon as I open a window slightly the pitch of the fan changes and the odor goes away. The camper is that air tight. I'm not sure why the trap in the drains aren't blocking this but this is what I've observed.
bsinc1962 is offline   Reply With Quote
Old 06-26-2019, 06:19 PM   #4
We just remedied a similar issue with our 2504S. We were smelling not so pleasant odor from the AC vent closest to the exhaust fan in the bathroom. After checking everything the determination was that the fan was sucking the black tank smells back into the roof cavity from the top of the black tank vent.
When I removed the vent cover I found that the hole the vent pipe travels through the roof is not sealed and there is a good sized gap around it. The stock vent cover also does not connect to the top of the vent pipe, it simply sits on top and covers it so I can see how with the right pressure gas could get sucked into the roof cavity from the pipe.
I replaced the vent covers with the ones that pivot with the wind (they also connect directly to the vent pipe vs. just covering it) and also sealed around the pipe where it exits the roof. That has solved the issue for us.
2016 Mini-Lite 2504S
2018 Chevy 3500 Duramax SRW
Ebills4595 is offline   Reply With Quote
Old 06-26-2019, 06:29 PM   #5
Some have reported their vent pipe has slipped down into their black tank. That *might* explain why you get odors only when the tank is full. Sorry, but not sure how to test if it has only partially slipped down.
Maybe get on the roof when the tank is full and blow hard on the vent pipe and see if it gurgles!?
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
Old 06-26-2019, 07:15 PM   #6
Flybob's Avatar
As mentioned above, the vent pipe may extend too far down in the tank either from slipping or assembled like that originally. Once the liquid gets above the vent, you no longer have a working vent.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-26-2019, 07:20 PM   #7
bedubya's Avatar
My cousin swears by this:
https://www.amazon.com/Lippert-Compo...74999996&psc=1
But I removed the cap (2 screws under a lot of caulking) and discovered the vent pipe stuck too far up. I cut it flush with the vent and it was much better.
'17 Toyota Tacoma 4x4 TRD Sport
'17 Salem Cruise Lite 232RBXL
'08 Kawasaki Vulcan Classic 1500
Mickey the Rescue Project Schnauzer
bedubya is offline   Reply With Quote
black, black tank, tank
