Old 04-17-2016, 03:13 PM   #1
Charles Firth's Avatar
black tank valve leaking
We just finished a few days in Charlottesville va at the KOA ( by the way great place ). I was dumping my holding tanks when I noticed I have a small leak on the black tank side. There is a small break close to the handle, it only leaks when the handle is pulled. I think I know the obvious answer, the valve needs to be replaced. Although the valve operates fine, just a crack on the outside. Has anyone had any luck putting some epoxy on the crack, or is just not worth the effort and just replace the valve. Only 4 bolts holding it, is it much of job ? Any secrets to replacing it ? Good news the tank is dumped and flushed. As always thanks for the help and advice.
Chuck " still in Va "
2012 3065w Windjammer
2012 f250 lariat Crew cab power stroke (of course )
Charles Firth is offline   Reply With Quote
black, black tank, leak, tank
