Old 07-06-2016, 02:20 AM   #1
hitch hiker's Avatar
black waste flush 8289ws
is the tank flush a bit like a jet wash inside the tank?
what is best to flush it out? leave tank closed or open?
thanks
ali
hitch hiker is offline   Reply With Quote
Old 07-06-2016, 02:57 AM   #2
Witch Doctor's Avatar
thanks
ali
Yes Kinda, I always leave it open and watch my clear elbow, then when I see just clean water I will close it for a minute and let it build up then pull it again. Then I ready to rock and roll again.....
Coachmen M/H
Concord
2018 / 300 DSC
Old 07-06-2016, 04:05 AM   #3
BamaBob's Avatar
thanks
ali
ALWAYS leave the tank OPEN (don't ask me how I know this )
When I dumped our tanks, I would do the black-gray dump process and then I would turn on the tank flush (yes it is just like a jet wash - a spinning arm at the top of the tank) and let it run until the water ran clear every time I dumped. In the 3 years we owned our Rockwood, we never had a problem with the sewer system.
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 07-06-2016, 05:31 AM   #4
Restcure's Avatar
We dump at home with a Flojet.
I'm still working on the procedure but here's what I've got so far (yes, it's detailed):
  1. Connect the Flojet and the drain hose
  2. Drain the black tank with the Flojet
  3. Connect the flush hose to the black tank rinser
  4. Turn on the flush hose
  5. Allow the black tank to fill for 30 seconds
  6. Drain the black tank with the Flojet
  7. Repeat steps 5 and 6 until water drains clear
  8. Allow the black tank to fill for 30 seconds
  9. Close the black tank valve (always good to have a little water in there)
  10. Turn off the flush hose
  11. Connect the flush hose to the Flojet flush port valve (as pictured above). This is a one-way valve that allows water in, but not out
  12. Turn on the flush hose (leave the flush port valve closed)
  13. Drain the galley tank with the Flojet
  14. Open the Flojet flush port valve
  15. Allow the galley tank to fill for 30 seconds
  16. Close the Flojet flush port valve
  17. Drain the galley tank with the Flojet
  18. Repeat steps 13-16 until water drains clear
  19. Allow the galley tank to fill for 30 seconds
  20. Close the galley valve
  21. Repeat steps 13-20 for the bathroom grey tank
  22. With all tank valves closed, open the Flojet flush valve port
  23. Immediately drain the clear water (otherwise the flushing water will pressurize the pipes and leak out of the valves, which can't be good)
  24. Keep flushing and draining for 30 seconds to clean out the drain hose (the Flojet will retain some water - no worries)
  25. Turn off the flush hose
  26. Close the Flojet flush port valve and disconnect the flush hose
  27. Open the Flojet flush port valve to allow air inside
  28. Drain the remainder of the clear flush water
  29. Disconnect the drain hose
  30. Disconnect the Flojet
I know it looks complicated but it's really not!
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
Restcure is offline   Reply With Quote
Old 07-06-2016, 05:43 AM   #5
JD could this be done from a I phone also for remote use? Youroo!!
youroo is online now   Reply With Quote
Old 07-06-2016, 08:04 AM   #6
2016 Rockwood 8325SS
Open the valve while using the tank flushing system. After the water becomes clear, close the valve let and let the tank fill for about a minute, then open the valve again. After you do this make sure that you leave a small amount water in the black tank so that the bottom of the tank does not dry out.
Barstorm is offline   Reply With Quote
Old 07-06-2016, 08:17 AM   #7
Restcure's Avatar
I wish! For now I just use the smartphone's stopwatch app.
Old 07-06-2016, 12:12 PM   #8
Life is great's Avatar
Barstorm, you say leave a little bit of water in the bottom of the tank so it doesn't dry out.....are tanks known to dry out. I haven't heard that before.
I have the black tank flush and love it! Camper is 4yrs old and my gauges still work and don't miss read.
2012 Rockwood Signature Ultra Lite 8312SS riding on Gladiator rubber.
2004 Ford F350 (Black Beauty) CC, SB, 6sp, 6L work horse.
Camped
2016 - 21 nights
2017 - 42 + scheduled....
Life is great is offline   Reply With Quote
Old 07-06-2016, 12:14 PM   #9
Some guy in back...
All the evidence points to the use of a clear elbow and anything the shoots a jet of water up into the tank from the valve end does and proves nothing. The blank tank flush devices set into the tank itself do some good, but why do we care so much? I agree some water left in the tank, making sure the "black pyramid" does not form are reasonable things, but cleaning the black tank so methodically? I really don't get it. To each their own and since it causes no harm to anyone else, more power to you!
ChateauV10
SF Bay Area
'99 Ford E350 V10
'16 Rockwood 8329SS
ChateauV10 is offline   Reply With Quote
Old 07-06-2016, 12:28 PM   #10
x2
2012 Ecoboost Screw, 3.31 (yes....really) rear end.
2016 Flagstaff 26FKWS, about 7500 loaded
Retired AF Mustang.....Picker always looking to jam.
Major Oz is offline   Reply With Quote
black
