I installed my own Tornado Black Tank Rinse. I decided to use pvc instead of the cheap hose that came with the kit. The kit came with this anti siphon valve. I was going to put it on the end of the hose before using but now I am thinking it should be inline. Is the anti siphon good enough? A01-0141VP RV anti siphon valve
That is the one I use on the end of my (Black) rinse supply hose. I just screw it on the outside of the Trailer as needed. I also have a good anti valve perm. mount on the inside,my personal choice. Youroo!!
I have seen (Rinsing devices) installed through the frame or below,behind the skirting,then over to the Black tank. The end result is level or even a little lower than the Black tank,not a good install! You need proper (vertical elevation) on the supply rinse line,with a (Anti-Siphoning device). Youroo!!
That is the one on my gray tank rinser. It is mounted right at the tank jet so the hose does not fill up with crud from the gray water tank.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
