Old 02-07-2013, 08:01 PM   #21
VinceU's Avatar
Originally Posted by f1100turbo
ASK and ye shall receive !
Nelson Remote Faucet Control - GEMPLER'S
Sometimes I even amaze myself !
Turbs
Good find Turbs, but think this is one control you'll want "close to hand"!
Old 02-07-2013, 08:04 PM   #22
TURBS's Avatar
RIGHT !
Old 02-07-2013, 08:36 PM   #23
Originally Posted by herk7769 View Post
I have to tell you, I still use my 12 foot "Black" hose for the turb-flushers even though I have double redundant brass check valves on the shut off.
The white hose is only used for drinking.
X2, not gonna risk infecting my drinking water hose.
jtaylor1920 is offline   Reply With Quote
Old 02-07-2013, 10:58 PM   #24
Herk7769's Avatar
Turbs
Holy Crap! I feel so inadequate...
HAM CALLSIGN - KC3FFW
Old 02-08-2013, 01:17 AM   #25
1l243's Avatar
I installed my own Tornado Black Tank Rinse. I decided to use pvc instead of the cheap hose that came with the kit. The kit came with this anti siphon valve. I was going to put it on the end of the hose before using but now I am thinking it should be inline. Is the anti siphon good enough?
A01-0141VP RV anti siphon valve
1l243 is offline   Reply With Quote
Old 02-08-2013, 05:41 AM   #26
That is the one I use on the end of my (Black) rinse supply hose. I just screw it on the outside of the Trailer as needed. I also have a good anti valve perm. mount on the inside,my personal choice. Youroo!!
Old 02-08-2013, 05:58 AM   #27
I have seen (Rinsing devices) installed through the frame or below,behind the skirting,then over to the Black tank. The end result is level or even a little lower than the Black tank,not a good install! You need proper (vertical elevation) on the supply rinse line,with a (Anti-Siphoning device). Youroo!!
Old 02-08-2013, 06:53 AM   #28
Herk7769's Avatar
That is the one on my gray tank rinser. It is mounted right at the tank jet so the hose does not fill up with crud from the gray water tank.
black water
