Old 02-07-2013, 02:44 PM   #1
RalphieAdie's Avatar
Black Water Flush
The black water flushing system works great, yet when we disconnect the hose from the side of the 5'er water comes back out of the inlet. Looking for a solution as to why this is happening.
Thanks.
Ralph & Adrienne
2016 Flagstaff 8528CKWSA
2012 GMC Sierra 2500HD 6.0L
RalphieAdie is offline   Reply With Quote
Old 02-07-2013, 03:25 PM   #2
There's a backflow prevention device a couple of feet in. The water that comes out is water in the hose prior to this device. Mine does the same thing. If you're ever not sure, capture it and look at it in a glass -- it's pure water.
F-350 Dually
Cedar Creek Silverback
Mazda Miata TOAD for sex appeal
danno2u is offline   Reply With Quote
Old 02-07-2013, 03:27 PM   #3
VinceU's Avatar
Thanks.
They all do it, the reason is the supply pipping heads up to about 3-4 feet above inlet level. Thats where the vac break is installed with non return. When you add water most climbs over the rise but the inlet side from the valve down has only one place to go-towards the operator. I learned to stay clear when I break the hose.
Old 02-07-2013, 03:47 PM   #4
Herk7769's Avatar
Here is what it looks like. (No worries the water flowing back out is as clean as the water you put in.)
that valve is located at the very top of the vanity cabinet in my camper. There is about 4 feet of PEX tubing from the Turboflush inlet to the check valve.
That check valve keeps black water from siphoning out the flush connection.
HAM CALLSIGN - KC3FFW
Old 02-07-2013, 04:15 PM   #5
Owner/Operator
RodeoGeorge's Avatar
I normally shut off the supply, and then disconnect the hose at the hose bib. That drains the water out the hose, and I do not get a bath when I disconnect the hose from the RV.
And if there's grass in the vicinity of the hose bib, it gets a drink.
RodeoGeorge
RodeoGeorge is offline   Reply With Quote
Old 02-07-2013, 05:47 PM   #6
Herk7769's Avatar
I have to tell you, I still use my 12 foot "Black" hose for the turb-flushers even though I have double redundant brass check valves on the shut off.
The white hose is only used for drinking.
Old 02-07-2013, 05:53 PM   #7
This is the backflow set up in my V ,notice how much insulation is on the O/S shower enclosuer-0%. The one in the Pic was the O/E plastic leaker that flooded the Bathroom first time using it,what a mess! Had to cut a access opening to gain way to repair the problem,major deal really. Youroo!!
ID:	24061   Click image for larger version
youroo is online now   Reply With Quote
Old 02-07-2013, 06:12 PM   #8
I put another check valve on the inside right at the hose connection and get no back flow whatsoever. I use a 50' "Pocket hose" with a shut off on the end and shut the water off at the campground faucet and the let the hose collapse to a "just barely charged" condition and then shut it off. This leaves a little water in the black tank to which I add about a cup of Super Clean. Leaves the tank clean and keeps stuff from solidifying in the tank.
Old 02-07-2013, 06:36 PM   #9
Not-so-Junior Member
VenturaBill's Avatar
Originally Posted by OldCoot View Post
...I use a 50' "Pocket hose" with a shut off on the end and shut the water off at the campground faucet and the let the hose collapse to a "just barely charged" condition and then shut it off.
Is that the same "pocket hose" seen on TV for $9.95? If so, do you like it?
How is it one careless match can start a forest fire, but it takes a whole box to start a campfire?
• 2012 F250 6.7L Lariat 4x4 long bed
• 2013 Columbus 295RL
• 1952 Blonde Nurse
VenturaBill is offline   Reply With Quote
Old 02-07-2013, 06:40 PM   #10
I like it a lot, according to the instructions it should not be left with pressure on it for long periods of time, so I just deflate it about half between flushes. Like the idea of being able to store the 50' hose in a "3#" coffee can and put a lid on it.
black water
