10-20-2016, 10:36 AM
Newbie
Boondocking question
This will be our first time boondocking and therefore using the fresh water tank and we have what's I'm sure a dumb question. Does the water heater work the same? Fill the fresh water tank, turn on the hot water tap inside and run it to fill the heater tank before turning on the heater? We have a '15 Mini Lite 2104s.
Susan & Jim
2014 Ford F-150 (white, of course!)
2015 Rockwood Mini Lite 2104s
10-20-2016, 10:48 AM
You got it right. Just make sure that you fill the WH prior. Or the WH will use 6g of water to fill.
2013 Rockwood Freedom2381G
2011 Dodge Ram 3500 Laramie 6.7L
B&W Turnover Ball w/Companion Hitch
10-20-2016, 10:59 AM
Charge the water system
You can preform the charging prior or after filling the fresh water tank. Make sure you hook up to city water prior to running your water pump or you will suck out valuable water from your tank to charge your lines and fill your heater. When you depart you should have as much water in your fresh tank as you think you need and all the lines and heater filled. Of course you can charge the lines from the fresh water tank and than top off the tank again. I do not do it that way because the pump takes a bit to fill the HW tank and I do not want to run it that much. City water is easier.
When I first started out with a rig I filled my fresh tank to 2/3 without filling the lines. When I turned on the pump it sucked 1/3 of the water out of my tank and I ran out of fresh water.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
10-20-2016, 11:20 AM
Newbie
Thank you so much for this info!!! We would not have this!!!
Susan & Jim
10-20-2016, 11:22 AM
Newbie
Thought if this.
Susan & Jim
10-20-2016, 12:53 PM
Since it is your first time using your Freshwater tank, you may want to sanitize it first.
Good luck and have fun!!!
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
10-20-2016, 09:43 PM
Newbie
Sanitizing taken care of. Thanks again everyone.
Susan & Jim
10-20-2016, 10:05 PM
OK you have the hot water taken care tanks sanitized but have you considered the most important part of boon docking, Steaks, dogs, wine, gin, tonic and such
Retired Navy
2016 Flagstaff 26 FKWS
10-21-2016, 06:55 AM
Newbie
Ha!!! Made a big pot of gumbo to take. Burgers ready for the grill. And a case of wine. I think we'll survive!
Susan & Jim
10-21-2016, 07:31 AM
NO NO NO NO!!!
It's steaks, dogs, beer, tequila, limeade and such....
Joy & Mel
2022 XLR Nitro 351
2022 Ram 3500HD MegaCab BigHorn 4x4 6.7L
2020 Indian Roadmaster
10-21-2016, 07:42 AM
Originally Posted by mele
NO NO NO NO!!!
No... no...
Steaks... moonshine... steaks... moonshine!
And then more moonshine!
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=64
10-21-2016, 08:24 AM
You ask about the W/H working the Same! Has your W/H got Both G/E option? Have you used the Gas side if equip? Have you filled your propane tank? How much Battery power do you have? Youroo!!
