Old 08-28-2016, 08:52 PM   #1
Cato's Avatar
both slides will not go in - 2604ws
went to put slides in...
living are slide makes a noise but no movement.
closet slide nothing.
Anyone?
checked fuses and have power
Cato is offline   Reply With Quote
Old 08-28-2016, 11:11 PM   #2
Croaker's Avatar
Are you running off battery or plugged in ?
Croaker is offline   Reply With Quote
Old 08-28-2016, 11:37 PM   #3
I owned a 2604WS and if I remember the wardrobe slide is an in wall schwintek motor and the main living room slide is an underfloor motor type. They are completely independent. I do remember there is a fuse between the battery and the slides. I'm not sure if it is for both or just the front. On mine it was located up in the tongue area just in front of the coach right before the wires go under the coach on the driver side.
You say you have power. Have you measured you battery voltage? When I hear that it makes noise but nothing happens I always think low battery...
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
dalford is online now   Reply With Quote
Old 08-29-2016, 05:53 AM   #4
Cato's Avatar
slides
plugged in.
Old 08-29-2016, 08:25 AM   #5
Cato's Avatar
Originally Posted by Cato View Post
plugged in.
well it seems the knob that cuts power to battery (under refrig) was pushed in with vacuum
sigh
All in!
thanks
Old 08-29-2016, 08:26 AM   #6
Cato's Avatar
sigh
All in!
thanks
Old 08-29-2016, 09:10 AM   #7
sigh
All in!
thanks
Oh yea, forgot about the battery cutoff .. Glad you found it..
2016 Siverback 33IK
Old 08-29-2016, 09:54 AM   #8
Cool
I need check and see if my 2016 2703WS has that "feature".
Marty
2016 Rockwood 2703WS Sapphire
2011 F150 Ecoboost SCAB/3.55
Martsing is offline   Reply With Quote
Old 08-29-2016, 02:42 PM   #9
Marty
Battery Disconnect Switch location
2016 Siverback 33IK
2604, slide, slide out
