Old 06-16-2015, 07:30 AM   #1
Bouncing 2608ws
My '15 2608 is great in many ways but if tends to bounce pretty good on some roads. Tends to be concert highways. I'm wondering what others experiences are? I'm been thinking that these 14" c rated tires are part of the problem. I'm on a 5 month trip out west from Florida and was not planning on replacing them until I return figuring I'd delay another expense for a year. Also wanted to move up to a 15" tire if I can. I just read that rims are rated and perhaps my OEM rim might not be able to handle handle greater pressure. Any opinions about this?
Robb
robbdrell is offline   Reply With Quote
Old 06-16-2015, 07:49 AM   #2
Your in for a interesting Ride! Putting on 15" tires and MORE pressure will develop (Hard Tires)! Using what came on the unit 14" NOT at full pressure will produce (Bounce)! You have (Rubber Ride) axles and NO shocks, hard to smooth out the (Vibration)! Youroo!!
Old 06-16-2015, 08:22 AM   #3
So do you mean that the bounce is inherent to this trailer? And higher PSI won't make a difference?
Robb
Old 06-17-2015, 03:56 AM   #4
Just a member
kandl's Avatar
As alluded to by Youroo, your TT has a torsion (rubber) suspension and by design, they bounce far less than their leaf spring counterparts. That could suggest that you may have issues with the torsion components in one of the axles. If so, larger tires will not help you out. I'd want to ensure that the four trailing arms of the suspension are indeed being supported by the rubber cords within the axles.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 06-17-2015, 06:51 AM   #5
TURBS's Avatar
Install shocks to dampin the bounce.
OldCoot installed them on his and found it considerably better.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-25-2015, 12:11 PM   #6
2016 Rockwood Ultra-Lite
radarman's Avatar
Just got the 2016 Rockwood 2608WS home after an initial 400 mile trip. Very little bounce at all and overall a smooth ride on the original 14" radial China tires running 55 PSI. Torsion bar suspension seems to work good. Probably will replace tires with other 14" tires this year. Dealer balanced the tires at no cost to me before picking up the trailer.
Jim and Connie w/3 lb. Chihuahua= Nugget
2016 Rockwood Ultra-Lite 2608WS
2004 Dodge Ram 2500
radarman is offline   Reply With Quote
Old 06-28-2015, 07:01 PM   #7
Dabmeb's Avatar
We have a 2013 2608 ws and have found it very sensitive to where you are adding weight to it. We have found that we need to keep most weight around the axles. There are other posts that talk about the balance issue with this model. I also upped my Reese dual cam bars from 800# to 1200# bars and this has helped. It's suprising how fast the tongue weight jumps on this trailer once you load the fridge and cabinets. The heavier bars and 4 links on the chains with the head tilted all the way back (6) and it pulls and rides much smoother and stable.
Dabmeb is offline   Reply With Quote
Old 06-28-2015, 09:12 PM   #8
Mine bounced right off the road and took my truck with it, totaled both. This is just a inherently unstable trailer IMHO and the axles should be upgraded to a pair of 5k's and moved back a foot.
hazmat456 is offline   Reply With Quote
Old 06-28-2015, 09:53 PM   #9
Dabmeb's Avatar
What I find very strange is the fact the total weight with Max cargo on this trailer is 6635 # yet only has 2 -3000# axles. The math is just wrong.
Old 06-28-2015, 09:55 PM   #10
Who Dares, Wins
doc73's Avatar
I remember reading a thread about the weight thing bef9re and someone said it was due to the fact that a certain amount of weight goes onto the TV not the axels.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
