Old 10-21-2011, 08:02 AM   #21
Hoo Dad's Avatar
Originally Posted by kwkincer View Post
Sorry for the confusion; I knew to use RV Antifreeze. I sure wish we could use automotive antifreeze, as I have about 10 gallons in the garage...
I ended up using the cheaper brand. The 2902ss took just over 3 gallons, probably half a gallon just to fill the filter canister. For $3/gal, no biggie.
MtnGuy, I too noticed the cheaper had ethyl alcohol, which was listed as the first ingredient. If non-consumable products follow the same guidelines as consumable products (doubtful), then there's more ethyl alcohol than anything else... The premium's ingredients listed "Other proprietary ingredients" at the end.
After I removed my filter, I inserted an empty (with the lid screwed back on) plastic soda bottle back into the filter housing prior to using the antifreeze. As you stated, however, the antifreeze at $3/gal is no biggie. After completing the winterization I removed the filter housing as I've read that some have had the housing freeze and crack if moisture was present in the threads. I then placed an empty coffee can under the male portion of the filter housing to catch any antifreeze that might leak out during the winter.
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
Hoo Dad is offline   Reply With Quote
Old 10-21-2011, 08:28 AM   #22
I'm terrified that I would forget that the filter housing is removed, and flood the entire camper in the spring. However, I might take this advice and put some reminders around my water connections. Thx!
kwkincer is offline   Reply With Quote
Old 10-21-2011, 09:44 AM   #23
We thought you did, but never can be too safe
Len & Cheri is offline   Reply With Quote
Old 10-21-2011, 09:49 AM   #24
I've done dumber things.. haha.
On the same note, I knew a guy that dumped 3 gallons of vehicle antifreeze into his well water. Hospitalized him for a few weeks... Lesson I'd rather not learn the hard way
Old 10-21-2011, 09:54 AM   #25
Herk7769's Avatar
He was Darn lucky (DUMB) but lucky. He would have been a Darwin Award winner for sure.
HAM CALLSIGN - KC3FFW
Old 10-21-2011, 12:20 PM   #26
Chillbilly's Avatar
Both are practically the same. I go for the less expensive one. But I just drain the lines and water heater, blow the lines out with a compressor, and fill the traps with anti-freeze. I've never had a problem. And, if we have a nice warm couple of days, we can go camping, and re-winterize afterwards without it costing us a small fortune. I usually use about a gallon of anti-freeze.
Chillbilly
2013 Rockwood Signature Ultra Lite 8244WS
2015 Ford F250 Quad Cab w/6.2 Engine
Chillbilly is offline   Reply With Quote
Old 10-21-2011, 12:38 PM   #27
TURBS's Avatar
new antifreeze
you know ............. Id like to try vodka for antifreeze since it wont freeze. I will just winterize the 5er with that then im thinkin all i have to do in the spring is get my glass full of ice and mixer of choice and camp out at the low point drains and mix my drinks !
multi purpose !
Old 10-21-2011, 02:41 PM   #28
MtnGuy's Avatar
multi purpose !
I had thought about that also. But the cheapest stuff is about $15 per 1/2 gallon, so that would make it pretty expensive compared to RV antifreeze.
I don't know what it would do the lines over winter, either.......it might just dissolve the lines.
Old 10-22-2011, 07:13 AM   #29
Phat Phrog Phlunky
essness's Avatar
multi purpose !
In the early to mid 80's We had trouble getting decent windshield washer fluid that wouldn't freeze in the extreme cold temps. I would mix vodka with the cheap stuff and that solved the problem Unfortunately, it always made me thirsty
Scot, I am "that guy"
2014 Raptor 27FS
2014 Ram 1500 Laramie
Days camped in 2013 = 30 final.
Days camped in 2014 = 27 final.
igkra.com
essness is offline   Reply With Quote
antifreeze
