Old 05-25-2011, 03:53 PM   #11
Capn Courage's Avatar
If you use the powdered Calgon just be sure to mix it well before poring it in your tank. I have noticed a couple times when I was less than diligent about mixing it in the pail that it left some crystal residue on the bottom of the pail.
Norm
Capn & Mrs C
Phoenix The Camping Sheltie
2006 Rockwood 8283SS
Capn Courage is offline   Reply With Quote
Old 05-25-2011, 04:48 PM   #12
miatared's Avatar
Has anyone ever seen the liquid version of Calgon in Ontario?
If so where ?
The powder version is available at some Loblaws (not all) and at Walmart too now it seems - will check it out. $8 a box at Loblaws.
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
Old 06-18-2011, 10:04 PM   #13
Look'in To Ecapé's Avatar
Was it the powder version you found in Walmart? Or liquid? What department did you find it in??
Roger & Dawn M.
2011 Rockwood Signature UltraLite 8315BSS
2004 Ford Excursion
Nights camped in 2011: 27
Nights camped in 2012: 34
Look'in To Ecapé is offline   Reply With Quote
Old 06-18-2011, 10:19 PM   #14
We too use one capful of the liquid from Walmart, haven't seen the powder. We also use a cup of detergent. Only thing we have ever used in our new HTT but did use the blue and other chemicals in previous campers and much prefer this way.
Donna=Me Tom=DH
2 DD's-grown, 1 DS grown, 1 DIL
4 DGD's, 1 DGS, 1 Pekingese(7/1/1999-6/18/2016)
2011 Shamrock 23ss
2000 Suburban 1500 4 X 4
ngts camped 2016-24 so far. reservations for 11 more
ilovecamping is offline   Reply With Quote
Old 06-18-2011, 11:16 PM   #15
Roger and Dawn, it's found in the same area as washing machine detergents and spray stain lifters, CLR, Soft Scrub, etc. At least that is where it is at my local Wal Mart. Some people purchase it online, as well, because sometimes it isn't available in their area. Randy
Old 06-19-2011, 02:09 AM   #16
2Susan's Avatar
Originally Posted by dretired View Post
And if you use calgon ..should you also be using the blue stuff that keeps odor down and helps to break up the waste ???
Nope!
The point of the Calgon is that because it helps the tank to empty more thoroughly you do not have the rotting sewage odor problem.
The tank additives are expensive, smell awful, and some are quite bad for the environment.
We have no tank odor and have used the Calgon for almost a year.
2011 Georgetown 320DS new June 2010
days camped in 2010: 61
days camped in 2011: 37 (up to Aug 1st)
2Susan is offline   Reply With Quote
Old 06-19-2011, 05:33 AM   #17
We have also only used the Geo Method in our TT for the last year. Never have a smell issue and tanks clean pretty quickly. I have a clear 45 deg adapter I place on the dump pipe before the sewer hose so I can see when it is cleaned. I am probably most anal about tank cleaning (no pun intended!). I have never used a chemical in our tank and have no plans to. When we find Calgon, we buy every bit we can and store it! We also add liquid laundry detergent (a cap full to a cup). Nothing special, just whatever we are using for the cloths.
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
Old 06-19-2011, 09:10 AM   #18
(Kim)
Labzy's Avatar
Do you let it sit in the tank between trips?
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 06-19-2011, 09:24 AM   #19
I empty my tanks, flush until visibly clean (then let it run for a while longer). I close everything up, put my Calgon and laundry detergent in, add about a gallon or so of water and then leave it until I flush next. I usually put some Calgon in the Gray tank every few trips as well and let that sit also.
Kirk, KN1B
