Old 04-19-2019, 12:49 AM   #1
Camera mount modification
Moved up from our PUP and
Will be getting a new rockwood 2104 S in about a month. Picked up a istrong camera for it. I’ll need to make a bracket to fit on the bolt pattern of the Furrion camera mounts that come stock with it. Has anyone done this or do you know of a Generic adapter plate?
Waterop is offline   Reply With Quote
Old 04-19-2019, 01:21 AM   #2
CincyGus's Avatar
https://www.haloview.com/haloview-ba...wired-rvs.html
The four screws on the tabs/ears of the bracket match the furrion mount once you remove the cover. The question is will the holes in the larger section work for you? For $6.99, I'd say it's worth a shot.
2020 Chevrolet 2500 LTZ, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart.
CincyGus is offline   Reply With Quote
Old 04-19-2019, 01:37 PM   #3
I bench tested it and it seems to be good. I’ll let you know how it does while traveling. The bracket looks like it would work. thanks
Old 04-20-2019, 03:46 PM   #4
I built my own adapter to convert from the Furrion mount to a Tadi Brothers camera, though they now sell an adapter kit. It probably doesn't apply for the camera you've got, but here are the pix of what I came up with (sorry about the sideways view). I chose to use clear plastic so I could tell if any leaking...been on for 2 years now with many miles and many rain showers and all good. (Irrelevant to the OP, but I replaced the onboard antennae with an extended one, mounted with glue to the front of the a/c unit.)
Enjoy your 2104S!!!!!
https://www.tadibrothers.com/product...-power-adapter
ID:	202327   Click image for larger version
Jack & April Connell
2017 Rockwood Mini Lite 2104S
Tow Vehicle: 2014 Jeep Grand Cherokee diesel
Blog for our trailer trips: www.jackandaprilblog.com
jackconn is offline   Reply With Quote
cat, mount
