Old 09-20-2015, 09:12 AM   #21
Done with this
Yep.
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 09-20-2015, 09:48 AM   #22
I am soooo confused!! I found this....its a 2016
Rockwood Ultra Lite 2604WS Specs
Sleeps
5
Slides
2
Hitch Weight
714 lbs
Ship Weight
5,779 lbs
Cargo Capacity
1,508 lbs
GVWR
7,714 lbs
Length
29'-6"
Height
9'-7"
Width
8'-0"
Fresh Water
36 gal
Gray Water
37 gal
Black Water
37 gal
L.P. Capacity
60 gal
Tire Size
15"
spower is offline   Reply With Quote
Old 09-20-2015, 11:17 AM   #23
Originally Posted by nomad297 View Post
Look at the sticker on the outside driver's side of your trailer. What does it specify for tire size?
Bruce
Sticker says 15, soooo??
Old 09-20-2015, 11:51 AM   #24
2016 Rockwood Ultra-Lite
radarman's Avatar
2608WS has 14", so i'm almost sure yours will also be 14".
Jim and Connie w/3 lb. Chihuahua= Nugget
2016 Rockwood Ultra-Lite 2608WS
2004 Dodge Ram 2500
radarman is offline   Reply With Quote
Old 09-20-2015, 12:00 PM   #25
Why on earth would you want to change from a 15" to a 14" and limit your tire LR options?
Old 09-20-2015, 12:13 PM   #26
I don't!!! Read the thread "3 hrs old..."
I am trying to find out what size my wheels should be. The problem you will see on the other thread may have happened because I have 15's on it and maybe it is supposed to have 14"s??
I can't seem to get a definitive answer. I will have to ask the factory I guess. I don't want 14's so not sure what they will do if I don't want it and that is what is needed to fix it.
Old 09-20-2015, 01:31 PM   #27
nomad297's Avatar
If you are forced to go to 14s by Forest River, they will have to provide you with a new tire loading sticker for the side of your trailer reflecting your new capacities with those 14s. The way it is now, everything matches. If you just go and change to 14s, you will have non-matching data if you don't get a new sticker.
Bruce
Old 09-20-2015, 01:32 PM   #28
nomad297's Avatar
Sleeps
5
Slides
2
Hitch Weight
714 lbs
Ship Weight
5,779 lbs
Cargo Capacity
1,508 lbs
GVWR
7,714 lbs
Length
29'-6"
Height
9'-7"
Width
8'-0"
Fresh Water
36 gal
Gray Water
37 gal
Black Water
37 gal
L.P. Capacity
60 gal
Tire Size
15"
Where did you find this?
Bruce
Old 09-20-2015, 01:45 PM   #29
DaveSchwartz's Avatar
And if they say that they should have been 14's, they owe you four new wheels and tires, delivered and installed at your location. Like I said on the other thread, I would not tow in that condition - tire failure just waiting to happen.
If they are the correct size, I think they still owe you an on-site fix because there's definitely a build safety issue here. If they resist, threaten them with a NHTSA report.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 09-20-2015, 01:53 PM   #30
Ford Idaho's Avatar
I'd file a report no matter what action is taken, this is a serious matter.
Old 09-20-2015, 10:47 PM   #31
Learning a lot as I go...
Hmm. I will have to double check my new 2016 2604WS. But I think I have read the side of the tires at 14". I will have to look at clearance too. Dark now, will have to wait for daylight.
stevejahr is offline   Reply With Quote
Old 09-20-2015, 10:51 PM   #32
Yes please let me know! Thanks...
Old 09-21-2015, 09:47 PM   #33
Ok, checked the TT and here is what I found, no internet data unreliability involved
Sticker data:
WRLT2604WS 3/18/2015 production (2016 model)
ST205/75R14C
Tire Data:
ST205/75R14 Load Range C
So pretty clear to me that 14" tires are the spec here unless there have been modifications or options chosen. I could see a lift kit including 15" tires for example. But that would also include blocks to raise the frame on the axles and create more clearance.
