Old 10-25-2012, 11:09 AM   #1
RalphieAdie's Avatar
Can't get the water filter canister off!!!!!!!!!!!
Just got out BEAUTIFUL 5th wheel and while it's 80 in STL today, it may be -20 tomorrow (it's STL). Anyway, we've been able to complete all of the other items as far as winterizing, we just can't get the empty water canister off to drain it. We just took delivery of the unit 2 weeks ago and decided to not install the filter this year.
Any thoughts. We've even tried to use an oil filter wrench, but don't want to break it.
HELP!
Ralph & Adrienne
2016 Flagstaff 8528CKWSA
2012 GMC Sierra 2500HD 6.0L
RalphieAdie is offline   Reply With Quote
Old 10-25-2012, 11:23 AM   #2
DeRosa2013's Avatar
Hold the top part real tight so you don't tear the plumbing out while twisting. Use the provided wrench tool that came with it. ( white plastic thing).. Also try releasing the pressure in the lines before removing. I there is pressure on the system it won't turn. Run your pump and open all the faucets until your out of water. Hope this may help.
Rob D.
DeRosa2013 is offline   Reply With Quote
Old 10-25-2012, 11:31 AM   #3
Witch Doctor's Avatar
HELP!
If you did not install the filter cartridge then you are done, you want anti in the container so it will not crack, taking the filter element out is optional depending. If it is still in it will not hurt anything but you would still have to replace it next season. Being you will never get all the anti out of the cartridge..............It sounds like you are done...
Old 10-25-2012, 11:31 AM   #4
Wanna Be Camper
SaskCampers's Avatar
You don't need to run the pump. Just open the faucets to release any pressure then it should come off fairly easy with the wrench. How did you winterize? With air blowing out the lines or using RV antifreeze. If it was antifreeze you can leave the canister full of the antifreeze, however if you just blew out the lines then for sure you need to empthy the water.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 10-25-2012, 11:34 AM   #5
TURBS's Avatar
You should have a whrench in the camper specifically for canister removal.
If you dealer is close go get it.
If not menards Lowe's and home depot carry them.
Any good hardware store as well.
The wrench may very well aid in the removal.
Turbs
Old 10-25-2012, 12:15 PM   #6
Now a "Top Member"
EdJunior's Avatar
Heh...like John (or Deb...TheSasks) said, release the pressure first. Mine was so tight I thought it was gonna break when I was turning (with the wrench). But as soon as I released the pressure, I could twist it off with my hand. I loosened a hose near the pump to release the pressure on mine. Never thought about just opening a faucet! Sheesh!
Ed and Sharon
2010 Wildcat 28RKBS
2011 Ford F-250 XLT, 6.7L PSD
Ride-Rite Airbags and Airlift wireless remote compressor...nice!
EdJunior is online now   Reply With Quote
Old 10-25-2012, 12:16 PM   #7
Thank you all for the help. Once I knew that I was looking for a white wrench, which I found, it was very easy.
I'm grateful for all the help that I receive on the forum.
Ralph & Adrienne
Old 10-25-2012, 02:48 PM   #8
Camper Less Camping
Cajun Po-Boy's Avatar
The day the Aussies make their beer cans with screw tops, you'll be able to use the same wrench! LOL
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 10-25-2012, 07:13 PM   #9
Trailer Trash
Used to drink those Aussie oil cans in the 80's. As Homer Simpson would say.............Mmmmm Fosters! They are about the size of a water filter canister.
joelek is offline   Reply With Quote
