Old 10-06-2012, 08:53 AM   #1
lindy's Avatar
Can't get WHOLE trl lever
When leveling I use a torpedo level on the floor in the front storage compartment. I can set the trl level front to rear and side to side. Then I can go to the back door and use the level on the floor there and it's 1/2 a bubble off level front to rear. Then I put the level on the counter top and it's off 1 whole buble front to rear, and the inside of the oven is the same. The inside of the fridge is off 1/2 a bubble also. The trl as been like this since day one and I seriously doubt there's an issue with the frame. Tire wear is nominal and the same on all 4 tires. Could be the builder that day was off 1/2 a bubble
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 10-06-2012, 08:57 AM   #2
I have a leveler one the front behind the hitch and another on the left side above the access door. when they are right I don't worry about it.
Jack
2006 Flagstaff 831RLSS Travel Trailer
2007 Chevy 2500HD 'Classic' with the Duramax engine.
Converting a 1956 GMC PD4501 Scenicruiser, ex Greyhound into a motor home.
jackhartjr is offline   Reply With Quote
Old 10-06-2012, 10:29 AM   #3
These campers are mass-produced, and there is little chance that all components would be perfectly aligned with one another.
When we bought ours, I leveled it as best as I could, then glued two levels in the hitch area. When we unhook, I just get those two levels as good as I can, and it is fine.
bakken is offline   Reply With Quote
Old 10-06-2012, 10:30 AM   #4
Hob
Two things have to be level, refrigerator so it works properly and the stove so the DW will cook. I've found TTs are like a house, nothing is exactly level.
Hob is offline   Reply With Quote
Old 10-06-2012, 11:24 AM   #5
Terier's Avatar
I used a bubble level that I move from one spot to another. Some places are more centered but all are pretty close to each other. I do one last test - see how the bathroom door reacts when open and close. Depending on the door results I will accept it as is or do more level adjustments.
Old 10-06-2012, 11:41 AM   #6
Dovetail's Avatar
That door test is also my last check. Good old gravity!
Rick and Linda, Lindale, TX
2011 Flagstaff 8528 CKSS
2006 F350 SW
Camping nights 2013: 130
Camping nights 2014: 17
Dovetail is offline   Reply With Quote
Old 10-06-2012, 02:05 PM   #7
First, lose the torpedo level and get at least a 18" - 24" level. Second, use the floor just inside the door for leveling your trailer. Don't use the countertop, 9 out of 10, the counter won't be level like the floor.
Ed & Laureen
2005 F-250 4X4 SD 6.0 Powerstroke
2009 Cherokee Wolf Pack 285wp (the side door ramp toy hauler)
nailit is offline   Reply With Quote
Old 10-06-2012, 02:35 PM   #8
lindy's Avatar
But like HOB said the stoves got to be level for the DW to bake the GOOD STUFF in the oven. The reasonI checked the oven was she cooked a peach upside down cake and it was higher by 3/4" on one side then the other. This got me thinking what is really level in the trl, so I started checking several places. Guess from now on I'll set the front to rear level according to level in the oven, I mean BAKED GOODS are the MOST IMPORTANT right?
F.R.O.G. member
