Old 10-27-2011, 09:18 AM   #11
Dave_Monica's Avatar
Originally Posted by Hoo Dad View Post
My understanding is that after I winterize I should remove the glass filter housing (also recommended by the filter housing manufacturer) and store dry. The reason being that if any moisture remains in the threads the housing will crack during freezing temperatures. Of course if there is no moisture in the threads then you will not have a problem but Murphy's Law follows me. So my goal is to not have to deal with the inside filter set up at all. I know I can have the system redone but I was looking for a more simpler method.
Hadn't heard that before. I've always taken the filter element out and emptied the housing and reinstalled. Haven't frozen/cracked the housing so far...I guess Murphy likes me!
You could still operate it without the filter element and use an in-line filter at the water connection when you camp.
Dave
Old 10-27-2011, 09:41 AM   #12
kz08h5's Avatar
I am looking to get rid of my filter housing also. Leaving the filter element out doesn't solve the issue of spilling water/antifreeze when removing the housing. I plan to cut the filter free from the PEX then replacing, with PEX, the section of line that was the filter housing. I found, online, push on PEX connectors. I have not personally checked them out yet. The brand is Shark Bite. I want to check them out before I pull the trigger on them. I am a little concerned about the road vibration over time. I don't want them working their way off.
These connectors aren't cheap, around $8.00 ea., but cheaper than buying a crimper. None of my neighbors have a PEX crimper, but I am still looking.
kz08h5
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
kz08h5 is offline   Reply With Quote
Old 10-27-2011, 10:35 AM   #13
Hoo Dad's Avatar
Exactly!
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
Hoo Dad is offline   Reply With Quote
Old 10-27-2011, 11:10 AM   #14
CLASS "A" Senior Member
cfsoistman's Avatar
Shark Bite fittings are available at Home Depot if you want to check them out firsthand.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 10-27-2011, 11:13 AM   #15
TURBS's Avatar
Exactly!
If you drain all your low point drains and open up allyour taps and showers. Then when everything is drain and closed back up turn your pump back on it will suck 80% of your water out of the housing
Therefore no mess!
I posted this a few days ago ........ read post water filter and winterizing
Old 10-27-2011, 11:22 AM   #16
Hoo Dad's Avatar
Making a mess isn't the only reason to eliminate the inside filter. I haven't made a mess yet. I'm trying to eliminate the minor hassle of having to deal with the inside system. Plus, after camping, and if you aren't going to camp again for a few weeks, you should remove the filter and store in a cold place to prevent mold from growing. You shouldn't bleach the filter. I don't want to have to remove the inside filter after camping each time.
Old 01-13-2012, 08:40 AM   #17
Even though I was diligent about draining my filter etc I had it break on me this year. Luckily I was at the Rv when it happened or the results would have been disastrous. I simply bypassed the filter at the housing then went to Wally World and bought a external RV filter for $15.
dredger is offline   Reply With Quote
Old 01-15-2012, 09:44 AM   #18
Playtime III
Playtime III's Avatar
I too want to bypass the filter for the same reasons. However, when I looked at customer reviews at the vendor link provided by f1100turbo below, all three comments were negative (everyone complaining of leaks).
Guess that leaves us with going to a permanent solution i.e. sharkbites and PEX scrap.
Playtime III
TT 2011 2902SS
TV 2007 F-150 SC 4x4 5.4
800 wd/dual cam sc
Playtime III is offline   Reply With Quote
Old 01-24-2012, 05:28 AM   #19
ret2006's Avatar
Here is a water filter winterizing by pass plate. Just eliminates filling the housing with pink stuff saving about a quart and half of RV anti-freeze. Also would make it easier and faster to flush out the system in the spring.
Amazon.com: Watts FP-WP100 3-5/8" Winterizing By-Pass Plate: Automotive
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 01-24-2012, 07:09 AM   #20
Great idea, but all reviews said it doesn't work.
I actually like my filter. On my last TT I used the outside filter and just didn't care for it.
Len & Cheri is offline   Reply With Quote
