Old 01-24-2012, 08:21 AM   #21
to winterize and bypass my waterfilter in bought a 12" x 6" pvc pipe nipple from home depot, unscrewed pex nuts from each side of filter and installed nipple, works great cost about 69 cents anf 5 minutes
Denny in Los Lunas is offline   Reply With Quote
Old 01-25-2012, 05:05 PM   #22
I took the filter out of my TT and threaded the two 1/2" PEX male thread adapters that went into each side of the filter into each side of a 1/2" brass ball valve so if for some reason I need or want to shut off the water to the camper plumbing fixtures I can without having to go out to the hydrant (my filter was located in an easy to get to cabinet). Would still have water press. up to that point but the rest of the camper would not.
wfkssvlite is offline   Reply With Quote
Old 03-18-2012, 09:49 AM   #23
Got mtn bike?
ddavis662's Avatar
Here's my mod.
Works great. After disconnecting from the water supply, the pump will pull most of the water out of the canister.
I maybe could have used a longer hose, but I didn't want to restrict any water flow
ddavis662 is offline   Reply With Quote
Old 03-18-2012, 10:44 AM   #24
Wanna Be Camper
SaskCampers's Avatar
If you put a glad kitchen catcher garbage bag around the filter housing before taking it off, no mess the little bit of water goes in the bag. We like the filter and for the 20 or 30 bux a year for a new carbon filter, it is worth it.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 03-29-2012, 10:42 AM   #25
One of the ball valves I bought does not work. Does it matter which way it is mounted?
Portagie1968 is offline   Reply With Quote
Old 03-29-2012, 10:42 AM   #26
Does any one know where I can get the plastic housing for the filter?
Old 04-19-2012, 06:49 PM   #27
We too had to order one...WaterPur Filters
mooneybeem is offline   Reply With Quote
Old 04-19-2012, 07:05 PM   #28
Submarines once..........
melbornj's Avatar
I broke the housing for my filter once while on a camping trip. I just disconnected the water lines from the filter and it turns out one side is male ant the other is female and they connected together. At least that is the way it worked on our 2008 rockwood PUP
Jason and Melissa
2013 ROO 233S AKA Our "ROO"ST
2008 Ford F-250
63 Nights in 2012! 8 Nights and counting in 2013
Four high energy Little Girls!:
melbornj is offline   Reply With Quote
Old 04-19-2012, 08:35 PM   #29
Shark Bite fittings are great! No problems. We us them for plumbing repairs in commercial property all the time..
Bruce and Lynn is offline   Reply With Quote
