Old 10-26-2011, 12:42 PM   #1
Hoo Dad's Avatar
Capping/Blanking Off Water Filter Housing
Instead of changing the plumbing in order to eliminate the inside water filter has anyone found a cap (probably around 4") to just screw onto the male fitting of the water filter canister top? Mine is a Model CCI-10-CLW.
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
Hoo Dad is offline   Reply With Quote
Old 10-26-2011, 12:54 PM   #2
TURBS's Avatar
Why not just get a coupler for both hoses and couple them together?
rv centers sell a block off plate to
Old 10-26-2011, 01:36 PM   #3
Hoo Dad's Avatar
This is what I have. Hopefully it worked.
Name:	filter housing connection.jpg
Old 10-26-2011, 02:41 PM   #4
Hoo Dad's Avatar
Hey turbo, Will the block off plate you mentioned block off (thread on) the white filter housing? If so, where have you seen this item? I can't find one. Thanks
Old 10-26-2011, 03:17 PM   #5
TURBS's Avatar
I seen them for sure on camping worlds web site
RV Supplies, RV Accessories & RV Parts for Motorhomes, Campers, Travel Trailers & 5th Wheel Campers - fifth wheel camper - Camping World
Old 10-26-2011, 03:26 PM   #6
TURBS's Avatar
RV Parts, RV Supplies, 5th Wheel Hitches, RV Accessories, Motorhome Parts, Camper Supplies
Part number is fp-wp100
8.00
Old 10-26-2011, 03:56 PM   #7
Hoo Dad's Avatar
Thanks for the info! I'm still wondering if I can purchase a pvc threaded cap to screw onto the filter housing. I'll check at a hardware store. If not, I may try the bypass plate
Old 10-26-2011, 05:46 PM   #8
Dave_Monica's Avatar
If you don't want to use the water filter, why not just leave the filter element out and screw the housing back on.
Dave
Old 10-26-2011, 07:42 PM   #9
j2detroit's Avatar
i just took ours completely out and added a peice of water line in we use an outside filter and have been for the last5 years works great and changing the filter is a lot less of a pain
j2detroit is offline   Reply With Quote
Old 10-27-2011, 05:32 AM   #10
Hoo Dad's Avatar
Dave
My understanding is that after I winterize I should remove the glass filter housing (also recommended by the filter housing manufacturer) and store dry. The reason being that if any moisture remains in the threads the housing will crack during freezing temperatures. Of course if there is no moisture in the threads then you will not have a problem but Murphy's Law follows me. So my goal is to not have to deal with the inside filter set up at all. I know I can have the system redone but I was looking for a more simpler method.
