Old 06-15-2012, 12:11 PM   #1
Alpineman's Avatar
Changing flat tire travel trailer
I have a Rockwood 2702SS with a spare on back. Does the trailer come with a jack and lug wrench somewhere like a car? Maybe a dumb question but I am new to this and want to be prepared.
Thanks in advance.
Alpineman is offline   Reply With Quote
Old 06-15-2012, 12:18 PM   #2
TURBS's Avatar
Unfortunately no on the jack and maybe on the lug wrench.
My flagstaff came with a socket my palomino did not.
Old 06-15-2012, 12:22 PM   #3
Alpineman's Avatar
F11000turbo,
Kind of figured that, i did find the socket attachment. I wonder if my truck jack would work, probably would. What would you reccomend to be prepared to change a flat?
thanks
Old 06-15-2012, 12:28 PM   #4
Originally Posted by Alpineman View Post
F11000turbo,
thanks
I had always used my truck jack, but because this one has different axles I bought a bottle jack.
Len & Cheri is offline   Reply With Quote
Old 06-15-2012, 12:30 PM   #5
TURBS's Avatar
F11000turbo,
thanks
Id try your truck jack before you hit the road to make sure it will work.
I made sure mine fit under the axle before we had a big trip.
Bought a socket and breaker bar.
When jacking on axle jack as close to wheel as possible.
Old 06-15-2012, 12:32 PM   #6
1/2 inch Torque wrench-6 inch long 1/2 drive ext.-6 pt socket,size to fit trailer nuts-material to make ramp,if torsion axle-jack if leaf spring. Youroo!!
Old 06-15-2012, 12:33 PM   #7
We learned the hard way years ago that a truck jack just wouldn't do it. Now carry a bottle jack at all times.
jmswms is offline   Reply With Quote
Old 06-15-2012, 12:33 PM   #8
RossandDonna's Avatar
No unfortunately you will have to supply your own. Some people use bottle jacks and some use a product called Trailer Aid. You can buy a lug wrench or use a socket and breaker bar or what ever you like for the lugs.
2012 Crusader 290RLT
2013 F350 Lariat Crew Cab DRW 6.7L Diesel
RossandDonna is offline   Reply With Quote
Old 06-15-2012, 12:42 PM   #9
If you have the Lego-type levellers or wood level blocks, pull your trailer onto the levellers so that the "good" tire on that side is on the blocks. This should raise the flat tire high enough to be removed/replaced. It may take 2 or 3 block layers to accomplish this. Block the opposite side wheels and/or leave tow vehicle hitched up to prevent the trailer from rolling off of the levellers. This is an alternative to carrying a bottle jack with you.
...VTX-Al
VTX Al is offline   Reply With Quote
Old 06-15-2012, 12:53 PM   #10
TURBS's Avatar
...VTX-Al
X2
Old 06-15-2012, 01:29 PM   #11
punkaccountant's Avatar
I purchased a Trailer Aid Plus and keep it in one of the storage bays. It's similar to the lego levellers except it's sole purpose is to just drive the good tire onto it so you can change the flat one. I figured if I'm on the road I don't want to mess with jacks and levellers. I can't wait to try it out...NOT.
punkaccountant is offline   Reply With Quote
Old 06-15-2012, 03:28 PM   #12
Alpineman's Avatar
Thanks everyone I will get a plan together before heading to Wilson Lake KS from Denver next week.
Old 06-16-2012, 02:54 PM   #13
Paul & Sheri
pwb01's Avatar
While on the subject, what is the jacking point? Can we jack up the axel near the wheel? Will it take the load? I don't think jacking the frame will do it.
tip: using a bottle jack carry a good pad to put it on in case you're on soil or you just jack the jack into the ground.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
Old 06-16-2012, 05:54 PM   #14
Jack placement
Be careful about Jack placement. I believe your owners manuel will tell you place the jack under the frame not the axle, Check your owners manual
grayfox is offline   Reply With Quote
Old 06-16-2012, 06:45 PM   #15
fonzie's Avatar
I use a 20 ton jack as in this post:
http://www.forestriverforums.com/for...taff-1636.html
Fonzie
Old 06-18-2012, 09:50 PM   #16
dj3spots's Avatar
We use a "jiffy jack". It's a drive on/off trailer aid. Check it out on valleyvet.com. We've used it and it works great.
dj3spots is offline   Reply With Quote
