Old 04-10-2016, 01:27 PM   #1
jim
changing tires from load range c to load range d
Iv been reading on here about load c rated tires, so I went out and looked at mine to see and that's what forest river put on mine. This camper has pulled kinda hard and Im going to put some load D range tires on my camper. can anyone tell me were to put a jack under the camper to lift to take off the tires so I can take them to a tire shop. I don't trust tire shops at all so Im taking them off my self. 2016 windjammer 3029W Also wondering if I should have them balanced?
candace123 is offline   Reply With Quote
Old 04-10-2016, 02:28 PM   #2
tjm
I jack up from the frame as close to the axles as I can using blocks and bottle jacks.
tjm is offline   Reply With Quote
Old 04-10-2016, 02:32 PM   #3
fonzie's Avatar
This thread might help you....
How do I jack up Flagstaff?
Fonzie
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 04-10-2016, 10:08 PM   #4
Yep, I jack right between the tires as in the first picture of the posted thread.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 04-11-2016, 12:25 PM   #5
mike.t's Avatar
I would think you would want to have them balanced.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 04-11-2016, 12:43 PM   #6
You say that the trailer " pulled kinda hard " , new tires will not help that !
wanderingbob is offline   Reply With Quote
Old 04-11-2016, 12:56 PM   #7
D_B Travelers's Avatar
Balanced, yes. And if you decide to have a tire shop do the change out make sure their guys don't come rolling out a shop jack and put it under your axles. If I hadn't been standing where I could see them they would have bent my axles, even after I told them not to jack on the axle.
Do you have a TrailerAid? If not they are something you should have in your WJ as they allow you to lift one tire at a time without any jack at all. Great investment.
D_B Travelers - 35 nights in 2016... so far. 54 nights in 2015. 2014 Rockwood Windjammer 3001W Diamond Pkg, 2015 GMC 3500HD CC DRW Duramax, Equalizer 14K hitch, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 1996)
D_B Travelers is offline   Reply With Quote
Old 04-11-2016, 01:03 PM   #8
Georgia Frog Rally 2017
aceinspp's Avatar
I actually use two short 2x6 boards for that.
Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
Old 04-11-2016, 02:48 PM   #9
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
Candace123....We also have a 3029W and I upgraded to D's also. I would take the rig to a tire shop,,,,,it'd be a lot less headache.....and yes,,,,DEFINITELY get them spin balanced. I once had a salesman tell me that it wasn't necessary. Bull! A tire is a tire is a tire. An unbalanced tire cost me $5153 when it disintegrated in Ft Worth. Spend the money and don't let anybody tell you that you don't need balancing. Also I highly recommend a tire pressure/temperature monitoring system. If I had one at the time, I'd probably still have the $5153 in my bank account.
Grampa Jim is offline   Reply With Quote
Old 04-11-2016, 02:51 PM   #10
Lvn2tvl's Avatar
Always lift the frame just beyond the spring shackle mount. I use a 10 ton floor jack and to take weight off the tires and then enough to get the tire off. I always have the truck connected and the landing gear down with some pressure off the truck to make sure the trailer won't move. May sound like over kill but safety, safety is always first. Just in case you're not aware don't try to use the rear stablilzer to lift the trailer. They are to stabilize the trailer not lift it off the ground.
BTW: If you try to jack under the axle you can actually crush it and then you'll be replacing that as well as the tires before you can move the trailer anywhere.
16 Silverado 3500 HD 6.6 Duramax 4X4
(Still looking for newer FR 5er)
Ultimate Aluminum 5th Wheel Hitch, TST tire monitors
Semi-Retired February 3, 2014
Bob & Cindy
Lvn2tvl is offline   Reply With Quote
tire, tires
