Old 06-12-2016, 02:57 PM   #11
Try indoor/outdoor carpet runner from a home improvement store. It is cheap and sells by the foot. It comes 3' wide and may make two step treads per length needed. Use a carpet cement to make it adhere. I have a piece of this glued on a heavy duty dolly for the past couple of years. If it holds up to that abuse, it should work on the steps.
PenJoe is offline   Reply With Quote
Old 06-12-2016, 03:06 PM   #12
Originally Posted by Long Leaf Piners View Post
Is that yellow tape, or something else, on the front of each step to mark them, OC?
Yes, it is reflective tape just to make them more visible.
Old 06-12-2016, 03:30 PM   #13
I am like you, those carpet step covers are outragously priced. I went to Lowes and purchased some outdoor carpet and some tent canvas grommets. Cut to match and used plastic wire ties to hold on. I had those on my motorhome for 10 years and never wore out. I cut new ones for my travel trailer. I spent less than $10 for 2 sets of 3 steps each which came to 6 covers and a lot left over.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
Old 06-12-2016, 05:21 PM   #14
Hot Glue.
Has anyone had issues with the glue turning loose in high heat. I just went out to remeasure mine, its about 96 outside and you can't keep your hand on the step because it is soooooo hot. Just wondering.
2016 Rockwood Ultra Lite 2604WS (Emerald Pkg)
2015 F350 Superduty Powerstroke.
Trecker WDH Hitch
Lazyboy Recliner replaced Back two chairs.....
J-N-D Wtexas is offline   Reply With Quote
Old 06-12-2016, 05:29 PM   #15
Hasn't bothered mine and it is 91 here right now.
Old 06-13-2016, 10:44 AM   #16
Owner/Operator
RodeoGeorge's Avatar
I also used the adhesive Carpet Tiles, and in addition to using them on the outside step, I used them on the inside steps that lead up to the bath/bedroom.
I did this because of the dogs (miniature daschunds), who were having trouble getting up the steps and also scratching the floor in the process. I did the steps and a small area in front of the bathroom door at the top of the steps.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 06-13-2016, 03:34 PM   #17
jtatum65's Avatar
Originally Posted by OldCoot View Post
Outdoor carpet tile or get some outdoor carpet and just glue it down. We bought outdoor carpet tile in 12 and installed it and it is still holding good.
OC, did you just use the self adhesive tile or did you use glue to adhere them to the steps?
Jim & Evelyn Tatum
2013 Rockwood 8289WS FW
2016 Dodge Ram 2500 Big Horn 6.4L Hemi 4x4
Nights Camped 2017 = 27
Nights Camped 2016= 33
jtatum65 is offline   Reply With Quote
Old 06-13-2016, 06:41 PM   #18
Used self adhesive tile.
Old 06-13-2016, 06:45 PM   #19
Himcules's Avatar
if my steps ever need a new coating, i would put truck bed liner on them.. waterproof, damage proof, high friction for no slipping even when wet, and not too rough for even barefoot walking.. just spray it clean... can get from home depot and other retailers and diy it easily...
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
Himcules is offline   Reply With Quote
Old 06-15-2016, 08:16 AM   #20
Klbrown53's Avatar
Hey OldCoot,
That looks good!
Klbrown53 is offline   Reply With Quote
