Old 11-08-2014, 08:52 AM   #1
City water inlet ?
This is the 1st RV we have had that had a antifreeze inlet just below our city water inlet. My question is we winterized our RV yesterday thru this inlet. Do we have to run antifreeze thru the city water inlet?? On our other RV's we pumped it thru the system either by hand pumping thru the city water inlet or there was a hose by our water pump and we pumped it thru that way. Just wondering. Thanks Cyndi
CLewis is offline   Reply With Quote
Old 11-08-2014, 08:57 AM   #2
davel1971's Avatar
shouldn't be any reason to, especially if you blew it out with air first. The purpose of the antifreeze inlet is to use the on-board pump to pull antifreeze into system, where city water doesn't need pump
David & Lynn
Old 11-08-2014, 09:08 AM   #3
Dave,
We didn't blow out the lines. We just ran antifreeze thru them.
Old 11-08-2014, 09:11 AM   #4
LandJ's Avatar
I think you need to "burp" the city water inlet so the connector/check valve doesn't freeze. I found a YouTube video that shows how.
John and Linda
2016 Rockwood 2604WS
2017 Ram 3500 CTD SRW
2016 - 47 nights
2017 - 47 nights
LandJ is offline   Reply With Quote
Old 11-08-2014, 09:12 AM   #5
davel1971's Avatar
I guess there is a small possibility, depending on how system is set up, there could be a bit of water in the line between the city and switching valve
David & Lynn
Old 11-08-2014, 09:18 AM   #6
davel1971's Avatar
did you bypass water heater, drain water heater and low point drains before you pumped antifreeze through?
David & Lynn
Old 11-08-2014, 09:30 AM   #7
Yes we did bypass the water heater and drained it and opened low point drains,.
Old 11-08-2014, 09:31 AM   #8
Thanks I will burp the city water inlet
Old 11-08-2014, 09:52 AM   #9
mark0224's Avatar
If you look at the city inlet there is a hose washer with a screen on it take that out then look in you will see a small button like piece of plastic, push it with your finger but make sure your out of the way because it may spray you. You should see a little antifreeze drip out. If you blew it out you should be ok but it's nice to know you are defiantly ok.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 11-08-2014, 10:01 AM   #10
Yes! Youroo!!
water
