Old 07-22-2010, 02:47 PM   #1
Nights Camped in 2010 - 2
Cleaning the Roof 2604
All,
Reading through my information, I see the MFG recommends using Murphy's Oil Soap to clean the membrane. Has anyone used this method to clean their roof? The dealer was pushing a cleaning solution and conditioner st over 30 bucks a gallon. MOS is a lot cheaper if it does the same thing.
Also, is it safe to walk on the roof? I know that might sound stupid, but I really don't know and do not want to damage the foam or AC ducts that are cut into the foam. Is there a best practice out there to use? Thanks,
George Kelly
2011 Rockwood Ultra Light 2604
Dodge RAM 1500 Larime 4x4, 5.7 HEMI
Nights Camped 2010 = 18
Nights Camped 2011 = 15
sailingsuppo46 is offline   Reply With Quote
Old 07-22-2010, 04:31 PM   #2
Arn
Arn
MOS & a soft bristle brush on a long handle works great. Clean your skylight & all plastic covers first then do the TPO membrane. Roof is safe to walk on but make sure your shoes are clean. Any stones from a driveway etc. can do some serious damage to the membrane. I leave the trailer a little nose up for drainage & start at the front. For variety sometimes I leave nose down & start at the back. Budget a lot of time cuz you'll probably want to wash the rest of your trailer once you see what runs down from the roof. Be careful up there, it's a long way down!
Arn is offline   Reply With Quote
Old 07-22-2010, 08:26 PM   #3
milzat's Avatar
I second that.
milzat is offline   Reply With Quote
Old 07-22-2010, 09:51 PM   #4
Thanks. Plan togive her a good wash after she comes back from the dealer. Taking her in on Saturday for some warranty work. I figure she will need it after begin back on the lot for a few days.
Do you condition the rubber with anything besides MOS? Thanks,
George Kelly
Old 07-23-2010, 03:20 PM   #5
Arn
Arn
Not a rubber roof. It's vinyl (TPO). Supposedly tougher & more UV resistant than rubber. No treatment required, just a couple of washings a year.
Old 07-23-2010, 08:09 PM   #6
powerboatr's Avatar
MOS is a good emulsifier and not to strong, it works super and is again affordable,
it also wont eat off graphics on the sides and i have found its less prone to streaking as the day goes and your scrubbing the whole rig.
i barefoot on the roof, and move slow as it gets a bit slippery
i have also used the same car soap i use on all the other vehicles to do a great job as well, but tends to be SLICK up top
around roofs and flexible sealed joints
use a soap just strong enough to remove dead bugs and sap, but not harsh enough to breakdown the sealing properties of the caulks and bedding compounds that seal your vents and skylights
always rinse several times
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 07-24-2010, 07:26 AM   #7
Arn
Arn
Yikes, barefoot. It sure is slippery. I always wear soft rubber soles for traction. By the way powerboatr, that is a very impressive toad. Beats the heck out of anything I've seen.
2604, rockwood
