Old 07-08-2013, 10:13 AM   #1
Cold Temperature Use
I've got a 2703ws and planning to go to Nevada for the winter. The place I'm going (Fallon) does get some freezing weather but overall has very easy winters. I'm wondering how cold tolerant my unit is with the full underbelly cover. Will I still need to skirt it or put hay bales around it?
If this has been discussed, please point me in the right direction.
Thanks,
wyoman is offline   Reply With Quote
Old 07-08-2013, 04:54 PM   #2
I have spent many winters in Nevada and Utah in an rv, you won't have any issues as long as you run your furnace for heat and not electric heaters. Running the furnace dumps some heat into areas below the floor. I never used skirting or bales.
polkatronron is offline   Reply With Quote
Old 07-08-2013, 05:08 PM   #3
Witch Doctor's Avatar
I would look into a heated hose for water, they are little priciest but worth it during a long cold spell. I use to disconnect the water hose and store it in the belly and use the pump at night. next time I buy a heated water hose. ......
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 07-08-2013, 05:39 PM   #4
Playtime III
Playtime III's Avatar
Not familiar with 2703s... The furnace will consume propane quickly so you may want 2-30lb tanks or an Extended Stay connected to a larger tank. Heated tanks are a nice option as well.
Playtime III
TT 2011 2902SS
TV 2007 F-150 SC 4x4 5.4
800 wd/dual cam sc
Playtime III is offline   Reply With Quote
Old 08-17-2013, 09:47 PM   #5
Back on this subject
Can anyone tell me if the pipes are wrapped or if there is a layer of insullation covered by the belly wrap? I'll probably have to get a heated water line but Fallon does get some cold weather, it just doesn't keep much snow on the ground, when it does get snow.
Old 08-17-2013, 10:09 PM   #6
Brother Les's Avatar
I would say no, there is no heavy insulation and the pipes are not wrapped. It is very easy to see by taking out one or two bolts on the bottom side of the cover and pull it down a little. The heat duct piping is very thin walled and you will loose some heat from them into the underside of the unit. There is a thin bead of calking along the rail and under cover. replace that when you put the screws back in.
Brother Les
Old 08-17-2013, 10:15 PM   #7
Insullation Factor
The specs for the unit (2703WS) say it has R12 in the floors. That's why I asked about pipes being insullated or maybe just a layer of insullation above the belly wrap. I guess I'll open up a place and take a look, like you suggest.
Old 08-19-2013, 08:05 AM   #8
It may say that the floors are R12, but the pipes are between the floor and the 'belly wrap'.
Brother Les
Old 08-19-2013, 12:54 PM   #9
If you got the ARCTIC package, you will have 12v heaters on the tank and the elbows of the drain. Plus you should have a duct in the basement. The tanks will heat to 65 degrees with the elbows. I live in Virginia and do not even winterize with no problems at all, but I have the Arctic package on my unit.........When it drops to freezeing I disconnect the water hose and just use my pump. I haven't had a problem yet. I do insulate the out door shower area door.......
Old 08-20-2013, 01:27 PM   #10
Paul & Sheri
pwb01's Avatar
For a point of reference: In upstate New York last Memorial Day, day and night it was between 40 and 45 degrees for the 5 days we camped. I went through 40# of propane. The R7 insulation is not made for real cold weather and two 30's won't last but a week.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
