Old 10-24-2013, 05:26 PM   #1
RodeoGeorge's Avatar
Combine Dump Outlets
I'm wanted to do this mod for some time, but have hesitated because there is not enough material on the back side of the Galley Dump Valve to work with once the Valve Flange is removed. See picture (Note left side of flange where the heater tape is located).
To eliminate this problem, I removed the valve on the Galley Tank and then bolted the two halves of the Valve Mount back together using one of the Valve Seals to seal the connection. See Picture (note rubber seal between the two flanges).
The final product was better than I expected.
An added advantage to bolting the two Galley Dump flanges back together without the valve between the flanges is that should replacement of the new Galley Dump Valve be necessary, there is now a point where the plumbing on the right side of the valve can be removed (the section between the new valve and the previous Galley Dump Valve.
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
RodeoGeorge is offline   Reply With Quote
Old 10-25-2013, 07:43 AM   #2
jeepman71's Avatar
Nice job RodeoGeorge.
Jim, Julie and Rags the boss.
2015 Dodge CTD 3500 Bighorn pulling 2014 Wildcat 317RL. Life is good when spent with family and friends.
jeepman71 is offline   Reply With Quote
Old 08-04-2014, 08:31 PM   #3
Rsharrer's Avatar
Looks good. Think I'll do the same! Have had our 8289 for one year now. Pulled it over 8000 miles and spent 110 nights in it. No major problems. Love the layout. Pulls like a dream.
Rsharrer is offline   Reply With Quote
