Old 05-01-2014, 05:56 PM   #11
Bob Fields is the manager of the service dept. Help helped me a lot. He got me answers. bfields@concertone.com
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 05-01-2014, 06:27 PM   #12
B and B's Avatar
The remote buttons do stick at times. If the buttons stick on the control panel won't work either. I find the power button sticks on th remote and the volume buttons as well. The panel torqued is an issue and the fix as mentioned by Herk, Just loosen the screws.
B
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 05-01-2014, 07:44 PM   #13
Herk7769's Avatar
Bob fields has moved on and unfortunately (for us) no longer works at Concertone.
HAM CALLSIGN - KC3FFW
Old 05-02-2014, 10:43 PM   #14
Paul & Sheri
pwb01's Avatar
Mine is just the opposite. It won't shut off so I had to put a switch on the hot wire.
Sent from my DROID RAZR using Forest River Forums mobile app
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
Old 05-03-2014, 02:17 AM   #15
Witch Doctor's Avatar
Which wire did you add the switch to? I would like to shut it off to, I pulled the unit and Couldn't figure out which one was from the fuse to it? They have at least 12 to that panel. I added a switch to the CO detector but not the genesis yet. I don't like them making it hot all the time. I don't use the memory anyway.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 05-03-2014, 11:07 AM   #16
Paul & Sheri
pwb01's Avatar
I wish I could tell you without pulling the unit to see. I do remember that the positive wire was clearly shown in the manual and on a sticker on the back.
2006 Sunline T1950
2004 T@B T-16
Old 05-03-2014, 02:36 PM   #17
Herk7769's Avatar
Here are some schematics and photos that might help
Name:	Concertone Wiring.jpg
ID:	51514   Click image for larger version
Name:	ZX-800 connections.jpg
Old 05-03-2014, 04:05 PM   #18
Thanks Lou, I will pull the unit out tomorrow, and take a look.
Old 05-05-2014, 02:46 PM   #19
You should have the wiring diagram on the back of the unit.
FYI I have a 500 for parts if you need one. Unit works with b and c speakers but the amp did not work for a.
Old 05-05-2014, 02:49 PM   #20
Originally Posted by captainchaos View Post
The model of the digital surround system is a ZX500. I removed it from it's resting place in the RV yesterday and when I had it out I pressed the eject for the DC that was in it and low and behold it ejected but that was all it did. When I put it back it still didn't work.
I have one I removed the A channel surround sound was not working but the other features works if you need one for parts.
concertone
