Old 11-25-2016, 07:04 PM   #1
Concertone weak antenna
Anyone have a suggestion for getting better reception for the FM tuner? I'm not in an area where I should be having issues. Need a booster or better outside antenna?Click image for larger version
Name:	ImageUploadedByForest River Forums1480118645.666620.jpg
hotrodhenson is offline   Reply With Quote
Old 11-26-2016, 02:34 AM   #2
2007 WildCat 32QBBS
18CrewDually's Avatar
Did you pull the unit out to verify the antenna wire is plugged in? What is the condition of the antenna?
18CrewDually is offline   Reply With Quote
Old 11-26-2016, 08:41 AM   #3
I haven't pulled it out. I will do that. The antenna appears to be in good shape.
Old 11-26-2016, 09:02 AM   #4
WFD
Doesn't seem to matter if it's Concertone, Jensen, iRV.....they are all notoriously weak. Hard to imagine in this day of modern technology that the RV manufacturers haven't been able to solve this. I live in a city where any of our cheapest clock radios in the house will pick up all the radio signals, yet the radio in our trailer can barely pick up our strongest station. I once attached a clothes hanger to the antenna then it worked pretty good. There is a few threads in this forum where people have hooked up their radios to the tv antenna with success.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 11-27-2016, 01:09 PM   #5
AKA: 'tiredTeacher
awellis3's Avatar
Yep, I did that. I have great reception now that the radio uses the Telly's booster.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 11-27-2016, 01:34 PM   #6
Canadian Member
I recall that, too. How do you do it?
Old 11-28-2016, 11:23 AM   #7
AKA: 'tiredTeacher
awellis3's Avatar
Here's the link to RodeoGeorge's thread. I followed his instructions. The install info is in posts #17 and 19.
http://www.forestriverforums.com/for...s-36212-2.html
Wright and Penny
Richmond, Va.
Old 11-28-2016, 12:40 PM   #8
Canadian Member
Thanks! Sounds fairly easy. I probably just need to buy a splitter and the Motorola to F Connector adapter.
Old 11-29-2016, 11:18 AM   #9
I had the same problem. I checked the antenna mount and found that there was a grounding wire that was not connected. i attached it to ground and had much better reception. I think that they need a "ground plane" to work properly.
cabranch47
2009 Flagstaff HW27SC (NTU 2014)
1999 Ford F150
cabranch47 is offline   Reply With Quote
Old 11-29-2016, 11:30 AM   #10
Flybob's Avatar
Sometimes the radio uses the tv ant. If that is the case, try turning on antenna amp using small button on tv ant connection plate.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-29-2016, 11:57 AM   #11
SYE
SYE's Avatar
Wow, someone that still listens to live radio!!
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
SYE is offline   Reply With Quote
Old 11-29-2016, 12:28 PM   #12
Canadian Member
My TT has a separate antenna on the roof.
We have a great 70s/80s/90s FM station locally. I have free XM for 6 months on my new F-250 and its OK but not nice enough to pay for a subscription. I can plug in a USB key full of my favorite tunes if I'm travelling a long distance. The Concertone in the TT will only handle a very small SD card or USB, so its nice to have the option of live local radio at your destination.
Old 11-29-2016, 03:19 PM   #13
AKA: 'tiredTeacher
awellis3's Avatar
Oh, yes. NPR for Morning Edition, All Things Considered and Car Talk. I also like to sit by the fire, smoke a good seegar and listen to college football. In the evenings we read and listen to our satellite radio for background music. I camped for so many years without a television, I have to remind myself it's there.
Wright and Penny
Richmond, Va.
Old 11-29-2016, 07:08 PM   #14
SYE
SYE's Avatar
What are we going to do if they stop AM radio in the US like they are talking about doing. They did it in Europe already
Scott & Vicki
2021 4 reserved
Old 11-30-2016, 08:57 AM   #15
2007 WildCat 32QBBS
Probably wonder how it lasted this long.
Old 11-30-2016, 03:39 PM   #16
People still listen to AM radio?
Last time I did, it was about 1973. We were in the hills above Malibu, CA at 3am and were able to pick up WLS in Chicago, IL.
2011 Traverse LT, 3.6L, FWD
antenna, concertone
