Originally Posted by cajunmansion
2017 2906ws
Went camping the week after Christmas, temperature was in the low 30 had the propane heater running in the RV I had condensation build up in all the cabinets towards the ceiling. Anyone having this same issue.
We have this happen on occasion. The problem is more moisture in the air than it can hold when cooled by a surface that is exposed to the outside temperature (such as windows). The ceiling area being further from the ground (where temps are more stable) probably cools more than the lower areas.
For us it's usually a combination of not watching moisture "input" from showers and dishwasing and number of people combined with a cold spell that provides cold surfaces for moisture to condense on. People emit moisture as do dishwashing and showers.
I think showers are probably the biggest source of moisture so we wipe down the shower well after each use, wringing the wipe-down towel well into the shower drain or bath sink. Hanging up damp towels after the shower aggravates the situation though we've found that if we are careful with other moisture sources the towels alone are not a problem.
Try opening a window while washing dishes, maybe also turning on an overhead fan to route that moisture to the outdoors. Running the bath fan also helps get ride of shower moisture generated during the shower (still need to wipe down afterwards).
It can take a couple of days of effort to bring moisture content down (bedding and such store moisture) before you hit the cold snap, so watch the weather forecast and try to dry out the trailer ahead of that.
We've never tried monitoring the humidity in the RV but that might be helpful.
We in CA now but lived in Upstate NY fir 20 years and had to learn about controlling indoor humidity. Until we did, we would occasionally have water running down the walls under windows. A dehumidifier helped, but alone wasn't enough.
I have read about RV'ers using de-humifiers of one kind or another, but they are slow and not all that effective from what I've read. Easier to just control the sources of moisture.
