Old 01-25-2012, 07:23 PM   #1
punkaccountant's Avatar
Confused about Mini Lite weights
I recently ordered a Rockwood Mini Lite 2306 and am curious about the weights on their spec sheet. It says it has a dry ship weight of 3,646 with a GVWR of 4,718 leaving a little over 1,000 lbs for cargo. I understand that the dry ship weight doesn't mean anything and is before they add options and stuff so I am worried that I won't have much left for my cargo. Depending on where I go I sometimes like to travel with a full water tank and that adds 240 lbs. there alone. For those of you who have this model or similar, can you tell me what your weight is after options?
The other thing that worries me is the dry tongue weight is only 318 lbs. well short of the 12% I'd like for towing. Again, this is the dry weight before propane and battery. Do any of you know your tongue weight loaded for travel? Just curious about this too.
Any other words of wisdom or comments you have are welcome! I love this Forum to be able to bounce these questions off of everyone. Thanks in advance!
punkaccountant is offline   Reply With Quote
Old 01-26-2012, 10:44 AM   #2
(Kim)
Labzy's Avatar
Idk what my tongue weight is exactly but the cargo capacity is 840lbs on mine. I would tell you the exact weight with options but it is in storage and my memory has been crap lately ;p but I think around 3850lbs.....
There are some others here with the same TT so when they read this post I am sure they will chime in with more details
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 01-26-2012, 11:59 AM   #3
Herk7769's Avatar
If you have not weighed your camper it is a good idea to know what it actually weighs empty and loaded as you like for camping.
Since the OEMs only buy the minimum safe "everything" according to the listed GVW; there is no "safety buffer" engineered in. IMHO, the design actually has a "useful life" designed in (about 8 years) in order to assure that you will be back to buy a new one.
Here are some links and info on how and where to weigh your rig.
CAT Scale
Travel Trailer Weight Calculator
HAM CALLSIGN - KC3FFW
Old 01-26-2012, 12:12 PM   #4
Triguy's Avatar
Labzy - that memory thing comes with age
Hi OP,
Many light trailers, and usually anything marketed as mini-light, are going to have a lower payload. Its not bad, per se, as long as you are aware.
Not sure about how wise these words are, but I do have a few comments for you. And I apologize that this is long.
Don't travel with a full tank of water and instead fill up at the park. We carry a little for on-the-road bathroom breaks but I don't think I've ever traveled with a full tank.
The dry tongue weight is only an indicator of how the engineers balanced the trailer. Those units with bathroom, bunks, kitchen in the rear - anything heavy compared to the load up front - will have a smaller percentage of dry tongue weight to dry ship weight.
That 9% tongue weight is not what you will have when loaded. Propane and batteries will help to even the load and you may want to load your cargo closer to the front, on the bed for instance. I encourage you to weigh at a CAT scale to get an idea of how your load effects things like the TW. You can also use a Sherline to estimate the TW percentage assuming that you know what the loaded trailer weighs (again from a CAT scale).
Last, your trailer will come to you weighing more than the brochure states it is. Even before you load it and put in batteries and propane, any factory options and dealers options will all change the weight. Good news is that the yellow sticker for your trailer will show the weight with factory options, but not the rest. Another plug to weigh the trailer.
All good questions so keep 'em coming!
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 01-26-2012, 12:48 PM   #5
Newbie
pg_rider's Avatar
Triguy, I plan on weighing my 2306 at a CAT scale. Will I need to unhook the trailer from my truck to get a good estimate of the trailer weight? The guide on the CAT website shows the truck and trailer all being weighed at once (each truck and trailer axle on it's own scale).
Once I get a good weight for the trailer, can I just use a bathroom scale to measure my tongue weight? I.e. put the scale under the tongue wheel with the trailer disconnected from the truck. This assumes of course that my scale can handle 400+ punds
pg_rider is offline   Reply With Quote
Old 01-26-2012, 12:53 PM   #6
MtnGuy's Avatar
If you get the weight on your trailer axles (without the spring bars hooked up), and then weight the tongue, then that should get you an accurate trailer weight.
Here is how to weigh your trailer with bathroom scales: Hitching Up - Trailer - Tongue Weight
Old 01-26-2012, 01:32 PM   #7
Thanks for your advice. I plan to weigh the trailer when I get it. My fear is if the GVWR is indeed 4,718 and the dry weight listed on the brochure is 3,646 then there will be very little room (weight-wise) for gear. I'm sure others are in the same boat and they either 1) don't pay attention or 2) just ignore the GVWR and load whatever they wish. I wanted a lighter trailer and knew we would have to pack lighter but it never clicked when I looked at this unit regarding these weights. It looks like most Mini Lites have the same weight constraints.
Old 01-26-2012, 02:26 PM   #8
Herk7769's Avatar
Weigh the truck and trailer connected first but WITHOUT and WD bars installed in order to get a valid tounge weight. Add all wheel weights together to get "Combined Weight"
Then disconnect the trailer and drive back onto the scales for a second weight. The second weight is only a dollar more.
Subtract the weight of the unhitched truck axle loads from the hitched axle loads to find your actual load on the truck (tounge weight).
Old 01-26-2012, 03:09 PM   #9
trudinator's Avatar
I'm with Triguy on this one. Our dealer told us not to travel with full tanks; puts too much strain on the brackets that hold them up.
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 01-26-2012, 03:23 PM   #10
Terier's Avatar
Hi OP,
I noticed that was often the case with several trailers that I had checked out after buying my trailer. A local dealer has RVs on display in the Costco parking lot about once a month or so. I was just curious what the inside looked like so I compared the numbers too. Quickly I was happy that the CCC on my lightweight trailer was reasonable: CCC 3656 / dry weight 3631.
Once you do hit the scales you will have actual numbers to work with. I need to do this too but ran into problems doing it wrong. I got to find someone willing to come along and help me weigh my trailer.
