10-09-2015, 08:46 PM
Correct slide out operation
Ok I need some advice, I have a 2015 Rockwood 2703WS, I read the manual regarding the slide operation and it states when closing the slides, hold button until the slides stop and then release the button. When I went over the operation with the salesperson on delivery, he said open the slides until the slides start to stop and begin to make a ratchet nose but only briefly one or two clicks and when closing watch until they are almost closed and start to raise up and just as the slide ratchets one or two clicks release the button, service writer states don't let it ratchet, my question is what do you guys do? The wardrobe slide is a different design and you release the button when it stops, no problem, the others not sure the correct procedure, three people have three different answers. The slides I'm speaking of have a long drive shaft.
Tom and Julie
2015 Rockwood 2703WS Emerald
2012 GMC Sierra Crew 4x4 1500 SLT Z71
10-09-2015, 11:01 PM
I am a newbie to slides also and was told the same thing by the service guy who taught me about my trailer. Slide out until it ratchets once or twice, slide in until it ratchets once or twice. Hopefully that is the correct way to do it..
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, Sold Mar 2019.
MISSION COMPLETED!
10-12-2015, 07:18 AM
I open my slides until the ratcheting sound happens and close them that way too. Had the trailer sicne February and no issues. It was expalined to me that the ratcheting sound is a clutch on the slide mechanism that prevents it from being over extended or closed too tightly.
Jack and Jan
Nights camped 2014 - 8 | Nights camped 2015 - 23 | Nights camped 2016 - 24
2015 Ford Super Duty F350 > Blue Ox Swaypro WD Hitch > 2015 Rockwood Windjammer 3008W
10-12-2015, 07:23 AM
All three of my slides make the ratchet sound at full extension, but make no such sound at full retraction. My other travel trailer slides were the same. I extend until I hear the noise and I retract until the movement stops with no sound -- I can't force them to make the sound on the way in.
Bruce
10-12-2015, 11:57 AM
The swintek slide you hold for 3 seconds after full open/close this keeps them synced.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
10-12-2015, 12:07 PM
Bring it in till you hear the ratchet. That means the slide is in tight against the trailer and has a good seal on the gaskets. Take a walk out and look, both sides should be tight against the trailer.
Also, if you have them, make sure you use the lock bars. This does two things. Keeps the seal on the top of the slide tight and prevents the slide from going out while traveling. Just remember to remove them before extending the slide!
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
10-12-2015, 12:23 PM
We picked up our 8529IKBS this weekend and were told the same as mentioned above... 1-2 clicks out, 1-2 clicks in. I used this method during PDI and later when camping this weekend. I inspected both the in and out positions and everything appeared to stop and fit just as it should be.
Time will certainly tell and I could see where holding the switch for many clicks could be harmful to the clutch but I believe the 1-2 click method is correct.
10-12-2015, 12:37 PM
We've had ours since Spring 2009... we were instructed to go for 1-2 clicks in and out. Haven't had any troubles at all.
Joe & Sue - Camp Mutt Duke
2008 Flagstaff Super Lite 26RKS
2008 Ford F-150
10-12-2015, 01:19 PM
Jim
I've never heard of lock bars. Can you elaborate?
Donna and Bob (retired USAF),
fur babies Casey (mix), Lucy and Loki (standard poodles)
had a 2015 Rockwood 8281 WS - traded for another brand.
2016 RAM 3500
10-12-2015, 01:32 PM
Can someone explain what causes the ratchet sound? Some of my slides make it, some don't. It sounds as though some kind of gear is stripping...
10-12-2015, 01:45 PM
I was told it is a clutch in the slide out motor/gear linear actuator clicking and 1-2 clicks is normal routine.
On my unit, all three slides are built with the same slide out actuators, positioned under the slide out. All three of my slides act/sound the same when coming to a stop in or out.
Some units have slides with more than just one kind of slide actuator which may involve cables and/or gear rails on the slide out side wall. I believe these act differently or may not make a ratcheting noise at all.
10-12-2015, 02:01 PM
Slide operation
We also just recently purchased an RV with three slides. The dinette ratchets at the in/out points. The bedroom and closet slides do not ratchet. These have limit switches that are set for in/out positions. It works like your garage door operator. The dealer advised to allow the dinette to ratchet once or twice and to release the button when the other slides reach their max point.
10-12-2015, 03:49 PM
the lock bars are used as a mechanical stay between the slide and the trailer body, placed inside near the top of the slide, and a bit like an acrow prop. I had one on my first trailer but never used one since. I don't think they are needed.
peter
10-12-2015, 04:21 PM
On a slide there is a motor gear and a driven gear. The driven gear is held in mesh with a spring. When the slide is full in or out or it hits an obstruction it is design to unmesh, or slip gears. That is the ratcheting sound you hear. Once you hear this noise let off the control switch to maximize gear life.
10-12-2015, 04:51 PM
On those slides that do ratchet, release the button as soon as you hear the sound. I don't know exactly what goes on in the mechanism but I would describe it as a clutch to prevent damage.
10-12-2015, 05:12 PM
Sounds similar to how a clutch works in a drill/driver. Should not do any damage at all as this is how the clutches are designed to work and prevents over tightening.
10-12-2015, 05:17 PM
Until it ratchets a few clicks. Both in and out.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2006 model year Border Collie
10-12-2015, 08:02 PM
From Lipperts Schwintek In-Wall Slide-out Owners Manual, found here:
http://lci1.com/assets/content/suppo...-schwintek.pdf
Operation
Extending Slide-out Room
1. Level the unit.
2. Verify the battery is fully charged and hooked up to the electrical system.
3. Remove the transit bars (if so equipped).
4. Press and hold the IN/OUT switch (Fig. 1B) in the OUT position until the room is fully extended and stops moving.
NOTE: It is important to continue to press the slide-out switch for a few seconds after the room is fully extended until the motor shuts off. The control will sense that the room has stopped and will shut off the motor after a few seconds.
5. Release the switch, which will lock the room into position.
Retracting Slide-out Room
1. Verify the battery is fully charged and hooked-up to the electrical system.
2. Press and hold the IN/OUT switch (Fig. 1A) in the IN position until the room is fully retracted and stops moving.
NOTE: It is important to continue to press the slide-out switch for a few seconds after the room is fully retracted until the motor shuts off. The control will sense that the room has stopped and will shut off the motor after a few seconds.
3. Release the switch, which will lock the room into position.
4. Install the transit bars (if so equipped).
No mention of any "ratchet."
Mine doesn't ratchet. When the motor stalls, the current draw increases. When the controller sees the current increase, it shuts it off.
"Ratcheting" may be related to the type of slide you have. Mine has the motors "in the wall." Others have them under the trailer and use cables, etc. That may be the difference.
I would strongly suggest everyone get the owners manual for their brand/model of slide and do what it says.
2011 Traverse LT, 3.6L, FWD
10-12-2015, 09:35 PM
I think my wardrobe slide is schwintek, the other two have motors under trailer and ratchet
Tom and Julie
10-13-2015, 10:59 AM
On my PDI the tech told us to hold the button for 2 or 3 seconds after extending or retracting. That was on our Sunseeker 2250.
2017 Dynamax REV 24RB
2018 Ford F-150
