Old 10-09-2015, 08:46 PM   #1
NOREASTRV's Avatar
Correct slide out operation
Ok I need some advice, I have a 2015 Rockwood 2703WS, I read the manual regarding the slide operation and it states when closing the slides, hold button until the slides stop and then release the button. When I went over the operation with the salesperson on delivery, he said open the slides until the slides start to stop and begin to make a ratchet nose but only briefly one or two clicks and when closing watch until they are almost closed and start to raise up and just as the slide ratchets one or two clicks release the button, service writer states don't let it ratchet, my question is what do you guys do? The wardrobe slide is a different design and you release the button when it stops, no problem, the others not sure the correct procedure, three people have three different answers. The slides I'm speaking of have a long drive shaft.
Tom and Julie
2015 Rockwood 2703WS Emerald
2012 GMC Sierra Crew 4x4 1500 SLT Z71
NOREASTRV is offline   Reply With Quote
Old 10-09-2015, 11:01 PM   #2
gectisme's Avatar
I am a newbie to slides also and was told the same thing by the service guy who taught me about my trailer. Slide out until it ratchets once or twice, slide in until it ratchets once or twice. Hopefully that is the correct way to do it..
2016 Windjammer 3006WK
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, (not really used, left over from our truck camper). Equalizer E4 1.4k/14k WD Hitch. TST 507 TPMS. Furrion FOS48TA Observation Camera. Garmin RV-760 GPS. Honda 2000i Genny, PI EMS-PT30C.
MISSION COMPLETED!
gectisme is offline   Reply With Quote
Old 10-12-2015, 07:18 AM   #3
strat56's Avatar
I open my slides until the ratcheting sound happens and close them that way too. Had the trailer sicne February and no issues. It was expalined to me that the ratcheting sound is a clutch on the slide mechanism that prevents it from being over extended or closed too tightly.
Jack and Jan
Nights camped 2014 - 8 | Nights camped 2015 - 23 | Nights camped 2016 - 24
2015 Ford Super Duty F350 > Blue Ox Swaypro WD Hitch > 2015 Rockwood Windjammer 3008W
strat56 is offline   Reply With Quote
Old 10-12-2015, 07:23 AM   #4
nomad297's Avatar
All three of my slides make the ratchet sound at full extension, but make no such sound at full retraction. My other travel trailer slides were the same. I extend until I hear the noise and I retract until the movement stops with no sound -- I can't force them to make the sound on the way in.
Bruce
Old 10-12-2015, 11:57 AM   #5
Crusadernoob's Avatar
The swintek slide you hold for 3 seconds after full open/close this keeps them synced.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 14
Crusadernoob is offline   Reply With Quote
Old 10-12-2015, 12:07 PM   #6
Bring it in till you hear the ratchet. That means the slide is in tight against the trailer and has a good seal on the gaskets. Take a walk out and look, both sides should be tight against the trailer.
Also, if you have them, make sure you use the lock bars. This does two things. Keeps the seal on the top of the slide tight and prevents the slide from going out while traveling. Just remember to remove them before extending the slide!
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 10-12-2015, 12:23 PM   #7
Pickin' & Campin'
We picked up our 8529IKBS this weekend and were told the same as mentioned above... 1-2 clicks out, 1-2 clicks in. I used this method during PDI and later when camping this weekend. I inspected both the in and out positions and everything appeared to stop and fit just as it should be.
Time will certainly tell and I could see where holding the switch for many clicks could be harmful to the clutch but I believe the 1-2 click method is correct.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 10-12-2015, 12:37 PM   #8
We've had ours since Spring 2009... we were instructed to go for 1-2 clicks in and out. Haven't had any troubles at all.
Joe & Sue - Camp Mutt Dazey
2008 Flagstaff Super Lite 26RKS
2008 Ford F-150
hotzfamily is offline   Reply With Quote
Old 10-12-2015, 01:19 PM   #9
DNBINFV's Avatar
Jim
I've never heard of lock bars. Can you elaborate?
Donna and Bob (retired USAF),
fur babies Casey (mix), Lucy and Loki (standard poodles)
had a 2015 Rockwood 8281 WS - traded for another brand.
2016 RAM 3500
DNBINFV is offline   Reply With Quote
Old 10-12-2015, 01:32 PM   #10
Can someone explain what causes the ratchet sound? Some of my slides make it, some don't. It sounds as though some kind of gear is stripping...
MOODMAN is offline   Reply With Quote
slide, slide out
