Old 07-16-2019, 12:56 PM   #1
Couch in my 2304DS
I have a 2015 Rockwood Model 2304DS and I have continuing issues with the couch/Jack Knife bed. Essentially the couch portion SUCKS. The springs have given way as well as the foam padding and its now like sitting in a HOLE. Its so deep that the back of my legs rest against the metal frame. Since the couch fits in a tight place and has to fold down pretty flat (to allow the Murphy Bed to fold down) I have been unable to find a replacement. What can I do now.?? I had an Upholstery Shop attempt to add webbing between the springs, but that did no good. The trailer has not been used a lot ...just a couple of times each year. This couch should not have failed like this......HELP
Roger.
Refclown is offline   Reply With Quote
Old 07-18-2019, 12:21 PM   #2
Couch
Has anyone else had this problem with the fold down couch?
It should not have failed....but what can I replace it with? Any ideas??
Old 07-18-2019, 12:29 PM   #3
Can you post a photo of your issues with your couch?
I'm having a hard time understanding how a couch could self-destruct using it 8 times.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 07-18-2019, 03:03 PM   #4
bikendan's Avatar
Refclown, did you buy this trailer new or used?
I've never found a jackknife sofa that was comfortable. We had one in our old trailer.
Equalizer WDH
Old 07-18-2019, 04:49 PM   #5
I bought this brand new.......
Old 07-18-2019, 04:53 PM   #6
I am not a light weight....200 lbs...but this is ridiculous to have this couch fail. The pic's show what I had an upholstery shop do to try and fix it...but to know avail. The springs just totally gave way and when I sit on it now, the back of my knees rub against the steel frame
ID:	210211   Click image for larger version
ID:	210212   Click image for larger version
Old 07-18-2019, 05:16 PM   #7
I had a similar problem with our couch that folds down for the Murphy bed. At first I tried 3/4 plywood but it was too stiff and it felt like I was sitting on a rock. After some experimentation, 3/8 plywood put on top of the steel frame and and 2 carefully adjusted ratchet straps to fine tune the feel of the couch. Not an ideal solution to be sure but it works. Jay
2016 Rockwood 2504s.
TV: 2014 Silverado 1500 double cab.
Jay2504 is offline   Reply With Quote
Old 07-18-2019, 06:09 PM   #8
I have already tried that route....but it did not work worth a damn. Not enough padding left to not make it feel like I was sitting on a hard rock.....
