Old 06-21-2019, 10:41 AM   #1
Counter repair 2507s rockwood
DW spilled on the kitchen counter and it took the shiny finish off about 4 inch x 4 inch area. Is there any way to put the shine back on the counter. Thks
sims is offline   Reply With Quote
Old 06-21-2019, 10:52 AM   #2
Nothing I know of will replace the original shine on laminate, which is a thermally fused clear melamine. There is a product called "Countertop Magic", sold in spray cans, that will help a little but needs to be applied often. Nothing like new however.
Rich & Karen
West Michigan
Isata 3 24FW
Riverbend is offline   Reply With Quote
Old 06-22-2019, 06:25 AM   #3
Additionally, if the countertop is a solid surface material, very fine sandpaper used with an orbital sander is what is used to finish the surface.
Rich & Karen
West Michigan
Isata 3 24FW
Old 06-22-2019, 10:09 AM   #4
nomad297's Avatar
This most important thing we need to know is, what material is your countertop made of?
If it is Corian, it is a super-easy fix. If it is a laminate, thereís not much you can do about it.
Bruce
nomad297 is online now   Reply With Quote
Old 06-22-2019, 10:14 AM   #5
I'd be interested to know....what did he spill that took the shine off the counter top ?? Battery acid ?
TheWolfPaq82 is offline   Reply With Quote
Old 06-22-2019, 11:52 AM   #6
well the wife was gluing something with crazy glue and got some on the counter so she tried to take the glue off with a scrubby which made marks and made a dull look on it. you can notice it in the light.
Old 06-22-2019, 12:33 PM   #7
If you have a small orbital sander, put a fine ScotchBrite pad on your sander's pad and go to town. You can use fine sandpaper, as well, depending on the amount of shine you want.
Rich & Karen
West Michigan
Isata 3 24FW
Old 06-22-2019, 01:02 PM   #8
Better answer
The best way to restore the finish is to go to the auto parts store (Advance, AutoZone, O'Reilly's, NAPA, etc.) and get sheet of 800 wet/dry sandpaper and a sheet of 1200 wet/dry sandpaper.
Put a little water on the surface and polish with the 1200 paper. Be very gentle. All the color in melamine is in the thin top surface. You don't want to go through it. You should be able to restore the gloss in 5-10 minutes.
Start with the 1200. Only switch to the 800 if the 1200 is going too slow. If you do use the 800, you will have to use the 1200 briefly afterward.
And take the cyanoacrylate glue away from DW.
Larry
Larry-NC is offline   Reply With Quote
Old 06-22-2019, 01:07 PM   #9
Thks for info I do have a orbital sander so do I need anything else other than the fine Scotch bite pad to remove the dullness and make it shine again.
Old 06-22-2019, 01:09 PM   #10
Larry
Thks Larry think I need to tape her fingers together then she can't grab the bottle
Old 06-22-2019, 01:15 PM   #11
Larry
Pretty sure his top is solid surface. You're describing a fix you'd recommend for high pressure laminate, which is paper. The melamine is the clear coat that is chemically and thermally bonded to the paper, where all the color and design lives. Melamine in that application is nothing more than the clear coating, and you can't restore it. I worked alongside that industry for decades.
Rich & Karen
West Michigan
Isata 3 24FW
Old 06-22-2019, 01:15 PM   #12
varathane spray gloss laquer, works great on furniture that was jacked in my house with nail polish remover. Either feather it, or tape off, put one coat, then feather in another coat. Buff if needed with a car deoxidizer polish.
dannko is offline   Reply With Quote
Old 06-22-2019, 01:23 PM   #13
I used this on corianders and it worked great.
https://www.amazon.com/Micro-Mesh-Co...42025600&psc=1
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 06-22-2019, 01:25 PM   #14
Yes the counter is a solid surface!
Old 06-22-2019, 01:26 PM   #15
So are you saying very fine sandpaper won't bring shine back
Old 06-22-2019, 04:56 PM   #16
Solid surface counter repair
It is very easy to fix a solid surface counter like that. You need an orbital sander and several different grits of fine sandpaper. Start with P 400, then go finer to P 800, then P 1200 and finally P 1500. If the counter becomes too shiny go back one step in grit. I have done kitchen counters with this process in my home repair business. Sand it dry with the above products. This fine sandpaper can be purchased on the internet from Kingspor Woodworking Shop. Not a problem, super easy to fix. The solid surface product is amazing stuff.
Bev and Wynn, Iowa City, Iowa
2018 Rockwood Mini Lite 2511S
2015 Chevrolet 1500, 5.L, 3.42 gears
Iowa City Fix It is offline   Reply With Quote
Old 06-22-2019, 04:59 PM   #17
Sandpaper
If you want to try sanding, it send me a PM. I will mail you some sandpaper.
Old 06-22-2019, 05:27 PM   #18
When the gloss isn't there anymore how does sandpaper during it back. My thinking it would make things worse?
Old 06-22-2019, 05:28 PM   #19
Bring the gloss finish back
Old 06-22-2019, 05:52 PM   #20
Your top is a mix of polyester and acrylic, and fine sandpaper actually polishes it. As I mentioned previously, Scotch Brite pads are also commonly used in the end process to actually cut the shine down a bit, as it makes the finished surface more forgiving to scratches and blemishes. It's also a matter of taste. I was actually one of the first certified Corian fabricators more than 30 years ago. The technology hasn't changed a whole lot since back then, other than the chemical percentages.
Rich & Karen
West Michigan
Isata 3 24FW
repair, rockwood
