Old 08-05-2016, 06:07 PM   #1
Cowling Failure
I have a 2013 Rockwood 8289 WS and I've noticed the front cowling is deflecting inward just above the decal "Rockwood". It has not been struck, nor is there any evidence of damage. It appears to being caused by head wind as I drive. It got noticeably worse on a recent trip from California to Utah and back. Is it possible for wind to damage the front cowling? Anyone else?
Bstoermer53 is offline   Reply With Quote
Old 08-05-2016, 06:33 PM   #2
iowaborn's Avatar
If your talking about the front cap, then yes I too have the problem. My 5er is the Flagstaff 8528rsws which is a sister to the Rockwood line. The rubber trim on the metal that secures the cap to the roof tore loose on our last trip, I beleive because of the change in air movement caused by the deformation of the front cap collapse. I have service scheduled Aug 9th at the plant service facility. If you search the forum, you will find many members reporting the same problem.
2013 F-250 CrewCab 6.7 PowerStroke 4X4
2014 8528RSWS
iowaborn is offline   Reply With Quote
Old 08-05-2016, 07:11 PM   #3
Cowling Failure
Thank you, I will try to locate those threads. It sounds like something the manufacturer is aware of then...
Old 08-06-2016, 08:24 AM   #4
jtatum65's Avatar
This is a known issue with this problem on 2013 Rockwood FW's. If you call your Rockwood warranty rep, they will replace the cap, if you have a good dealer that can do it. Mine had to go back to the factory to be replaced as the dealer was not cooperative with Rockwood to get it done. They did on mine back in April, as I too have a 2013 8289WS.
Jim & Evelyn Tatum
2013 Rockwood 8289WS FW
2016 Dodge Ram 2500 Big Horn 6.4L Hemi 4x4
Nights Camped 2016= 33
# of Campgrounds= 11
Nights Camped 2015= 31 @ 7 CG
jtatum65 is offline   Reply With Quote
Old 08-07-2016, 01:38 AM   #5
Cowling Failure
Thank you!
Old 08-09-2016, 02:24 PM   #6
iowaborn's Avatar
Factory replaced my front cap today. I had them leave the decals off since I anticipated them curling again, even though I was told the decals should not do that.
Sent from my GT-N5110 using Tapatalk
2014 8528RSWS
