Old 05-02-2014, 05:54 AM   #1
Create a breeze fan
Hi, Noticed that my create a breeze fan dome does not close all the way. It closes tight on the side with the crank handle but not on the opposite side. It is a manual crank. There is a cover over it too. Any ideas on how to fix it? How do you remove the fan to access the dome from the inside?
gserve is offline   Reply With Quote
Old 05-02-2014, 06:00 AM   #2
DAISY BOYKIN's Avatar
Not closed right---------------
First I would remove the outer cover to see if the crank open cover is actually catching on something. Maybe the outer cover needs to be adjusted
or repositioned so the crank up cover does not hang up on the outer cover..
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 05-02-2014, 06:08 AM   #3
TURBS's Avatar
You cannot service the lid from the inside.
TURBS
Sabre owners united!
Old 05-02-2014, 08:35 AM   #4
AKA: 'tiredTeacher
awellis3's Avatar
Bingo! The vent lid needs to be moved a tad so it is centered. The lid is catching on the lip of the vent. I had to remove the vent hood and adjust mine.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 05-02-2014, 07:43 PM   #5
Went on the roof to check the dome. It looks like the hinge on the dome is not attached to the vent housing. I was able to move it and see the hinge moving around. I tried to remove the cover over the dome by removing the clips from the pins but it wouldn't come off because of excess dicor applied underneath it. How do I get it off? Also what is used to attach the hinge to the frame?
Old 05-02-2014, 07:54 PM   #6
Fivealive's Avatar
Call Fantastic vent at 800-521-0298. They have great customer service and will answer your questions.
Fivealive is offline   Reply With Quote
fan
