Old 05-22-2011, 05:16 PM   #11
Wanna Be Camper
SaskCampers's Avatar
Originally Posted by herk7769 View Post
I added another wall switch next to the single OEM one just to control the fan. I got it on eBay.
That is nice work Lou, only in our unit it already has 2 switches like in your pic. One for the overhead light and fan and the other for the vanity lights. Now do they make a triple switch unit is the question.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 05-22-2011, 05:23 PM   #12
dnm1987. We have a 1809s 2011 and I have no problem with this fantastic fan. The switch on the wall run the fan. You have 3 speeds to choose and the vent must be opened high enough in order to run the fan. I gess if you have exhausted all the possibilities than bring the trailer to the dealer. Try to have acces to the fan wiring direct and connect some 12 volts ( PORTABLE 12 VOLTS BATTERY)directly to the wires? good luck I hope you like your 1809s lots of room for the size of this trailer.
capucine is offline   Reply With Quote
Old 05-22-2011, 07:55 PM   #13
frankm's Avatar
Lou how difficult was this?
Not very. As with all my "simple jobs" it was harder than I thought. My 15 minute job took about 2 hours.
And did you have to run any new wires?
Yes, I used 14Ga double speaker wire (silver/Gold) to run power from the switch to the Vent. I used that because I had a 250 foot roll and no idea what to do with it!
I found the item on eBay NEW RV CAMPER 12V POWER VENT BATH LIGHT WALL SWITCH ON | eBay
That was the vendor. fast shipping with no issues.
Is it a matter of separating existing fan and light wires in the existing switch and connecting them to the new one then I can handle that.
Well, here is the deal. There is a single run of switched power to the fan shroud and a junction that then routes power to the fan; ceiling light fixture and vanity lights. I made a jumper that went from the "Lights" lug to the "Fan" lug. I tied the grounds together in the wall. Then I ran a new wire to the fan shroud and it was not all that hard to fish.
I used the existing run to pull the new run and a heavy string into the shroud. I untied the new run and pulled the existing run back into the switch box with the string. The lights switch now powers the ceiling lights and vanity lights. The fan switch just powers the fan.
I "could" be talked into taking the shroud apart and pulling the wall plate for photos, but not looking forward to it.
Did you have to enlarge the hole in the wall to accommodate the new switch?
Yes. The wall is very thin and cuts easily with a box cutter. (or even scissors)
Ok, I think I can do this. The detailed explanation eliminates the need for pictures.
Thanks!!
Frank & Rita M
2016 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
frankm is offline   Reply With Quote
Old 07-10-2012, 09:08 PM   #14
I have the same fan
I had the same problem with my fan and found the pressure switch had no spring in it so it wouldn't pop up when I opened the cover. I'm still looking for that part. if anyone has an idea would love to know where to pick one up.
jbrule is offline   Reply With Quote
Old 07-10-2012, 09:55 PM   #15
sherdep's Avatar
If it was me I would call the manufacture and tell them what is going on - and see if they will send you the piece.
After I bought my trailer and had issues with the rubber covers on the axles - I called and told them the situation and they sent me a few in the mail.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
fan
