Old 08-18-2015, 07:06 AM   #1
barryontheroad's Avatar
Curbside Only Blowouts
Although I've been reading items on this forum for a good while, this is my first post - hope I get it right, and I apologize in advance if I don't. In the three years since I took delivery of my FR 8265WS 5er, I've had five blowouts. On the right side only! This isn't my first trailer, or even my first fifth-wheel, but it is my first experience with this phenomenon. Finally, a solution occurred to me, and I wrote about it on my travel blog. Not sure if I can post a link to it here, but am happy to provide it privately. Long story short, I camp in two locations every year, in the exact same spot, for two to three weeks at a time. In both locations, I have to level up the right (door) side of the trailer. I have been using those orange plastic interlocking blocks that you are all familiar with. So, on the latest trip I placed a couple of thinner, smooth orange pieces (that I usually use under the front landing gear) on top of the regular blocks so that the tires rested on a smooth surface instead. This could just be anecdotal evidence, but I had no blowouts on the 1200 mile trip home. I report, you decide...
2013 Rockwood 8265WS Fifth wheel
2013 F150 Ecoboost
barryontheroad.com
70 nights on the road in 2015
barryontheroad is offline   Reply With Quote
Old 08-18-2015, 07:19 AM   #2
Alleged curmudgeon
Vern's Avatar
I have never heard anyone else suggest that the Lynx Levelers (without caps) would damage the tires, but I do use the caps on my Lynx Levelers because it seemed like a possibility. I have heard many suggest that door (curb) side blowouts might be related to sidewall weakness caused by curb strikes.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34)
Vern is offline   Reply With Quote
Old 08-18-2015, 07:24 AM   #3
Although I can't say for 100%, I'm at least 95% sure curb strikes have never occurred with my rig. Where do you get the caps for the leveling blocks?
2013 F150 Ecoboost
barryontheroad.com
Old 08-18-2015, 07:28 AM   #4
Fivealive's Avatar
Parking on leveling blocks really isn't much different than parking on gravel surfaces. Most damage that I've seen indicates sidewall failure; the tires are weaker there. There may be an alignment problem with your axles that is causing the tires to overheat. Curb damage can take it's toll. Are you heavier on the right side of your trailer and using tires that are close to the load limit? The right side could be heavier and requires leveling partially due to that.
Fivealive is offline   Reply With Quote
Old 08-18-2015, 08:13 AM   #5
I considered that, but wouldn't that mean that the left side was also out of alignment and subject to failure? In my blog post, I go into more detail about my search for the cause which included weight and load range issues. Even after I upgraded to Ds on the right side, I still had blowouts. But with Cs on the left, there was never a blowout.
2013 F150 Ecoboost
barryontheroad.com
Old 08-18-2015, 08:38 AM   #6
rsdata's Avatar
I vote for curb strikes, but certainly a look at the failed tires could provide a clue there. With all the rough surfaces you could possibly drive over or store your TT on, I really doubt that the plastic levelers are the problem.
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 08-18-2015, 09:09 AM   #7
PhoneDude 8289's Avatar
X2
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is online now   Reply With Quote
Old 08-18-2015, 09:32 AM   #8
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Could you weigh each side of the trailer individually and compare these numbers to the load ratings of the tires. Maxxed out tires are more likely to fail even with the best possible care.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is online now   Reply With Quote
Old 08-19-2015, 06:15 AM   #9
Alleged curmudgeon
Vern's Avatar
Tri-Lynx cap
Go to Amazon and search "Tri-Lynx cap" for the caps for Lynx levelers. They come in a set of 4.
Lee
