Old 06-15-2013, 02:17 PM   #1
David WAWA's Avatar
Custom Shelves
I would like to add shelves to my closet slide out and I'm wondering the best way to do this and if I can screw to the side and back walls safely.
David WAWA is offline   Reply With Quote
Old 06-15-2013, 02:38 PM   #2
I added drawers, you just have to use screws that just barely reach thru the thin paneling and use at least 3 on a side & end.
Name:	Closet drawer.jpg
ID:	33212   Click image for larger version
Name:	closet drawers extended.jpg
Old 06-18-2013, 07:41 PM   #3
Paul & Sheri
pwb01's Avatar
Looks good!
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
Old 06-25-2013, 11:23 AM   #4
calberry's Avatar
Nice looking drawers!
I did basically the same thing, but also in the hanging clothes wardrobe section I took out the bar (we don't travel with clothes that need to be hung up!) and put in 2 more drawers (side by side) at the bottom. Then I added two full width shelves in the space above the drawers. To do this I screwed/glued 1/2" x 1" trim on the sides and back of the opening, and then cut 1/4" plywood to exactly fit and sit on top of that. Ours is a double door opening with a center vertical wood stop for the doors, so I also ran another piece of trim from that piece to the trim on the back for both shelves to sit on to minimize sagging once fully packed.
I also installed similar drawers in the tall skinny single door kitchen cabinet to hold plates, glasses, utensils, etc. That was pretty tricky because the space between shelves in the cabinet was so high, and we didn't need drawers that deep...so I made 3 drawers to fit into one opening (each about 3" high, with about a 1" gap between them). VERY difficult to 1) reach in to mount the slides and 2) get them level.
I'd show pics but the rig is in storage now
Steve
calberry is offline   Reply With Quote
Old 06-25-2013, 12:10 PM   #5
dkb74's Avatar
I added shelves in our pantry, but used wire baskets so that items wouldn't slide out during travel.
Forest River Forums - dkb74's Album: 2014 Rockwood 2306 - Picture
~ Darlene ~
2014 Coachmen Mirada 35BH
previous owner of
2014 Rockwood Mini-Lite 2306
dkb74 is offline   Reply With Quote
Old 06-25-2013, 12:23 PM   #6
Gripper's Avatar
Nice, I am in the process of adding similar shelves to the pantry (looks identical to yours) but using draw slides because of the 2 foot depth. I did notice the shelves on mine were sitting on supports that were merely glued to the thin side walls. I added 1/2"x1" to both sides front and back top down (glued). Seemed very flimsy prior to the supports. I am now installing slides with wood as we will use one draw for can goods. I like your baskets for the others and may steel that idea, although will screw them to the wood base of slides this will save me some work.
Essex County
Southern most area in Canada
2015 F150 XLT Sport 5 ltr V8
2011 Flagstaff classic 31.5'BHDS
Gripper is offline   Reply With Quote
Old 06-25-2013, 03:35 PM   #7
calberry's Avatar
I just found this pic on my phone that I forgot I had. This is the BR wardrobe closet after the drawers and bottom shelf were in. I then added 2 more shelves in the space above that one.
Steve
Name:	Trailer shelf.jpg
Old 06-25-2013, 07:47 PM   #8
Fivealive's Avatar
Try using pop rivets. I have had great luck with everything I mounted to the panels on my ultralight.
Fivealive is offline   Reply With Quote
