Old 02-05-2013, 08:27 PM   #1
jeepman71's Avatar
Decal Install
As the title states I would like some oppinions on proper installation of some decals on my truck.
I have an 8289WS diamond package and a white pickup. I wanted some graphics on my truck that would be similar to the trailer graphics so I ordered the front graphic from Forrest River. This is a very heavy vinyl graphic That has a white backing. It is a 3M product called ScothCal High Performance Film Automotive Grade Performance with Comply Adhesive Performance.
It all seems like normal dry application graphics except the paper cover is cut exactly the same as the graphic itself. How does one remove the outer cove once the graphic is installed?
Thanks for the help
Jim
jeepman71 is offline   Reply With Quote
Old 02-05-2013, 08:35 PM   #2
Fire Instructor's Avatar
Spray the TT surface with a fine water mist. Apply the decal over the mist. Slide it to EXACTLY where you want it. Then, using a plastic straight edge, a medium size pan-scraper will work, start in the middle, and squeegee the water out from under the decal, being careful not to leave an air or water bubbles behind.
If you leave a small air or water bubble, and you can't work it out to an edge, try a small pin to let the air or water out, then squeegee it flat.
This is how the striping and lettering on fire apparatus is done.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 02-06-2013, 08:12 AM   #3
jeepman71's Avatar
Thanks for the reply Fire Instrutor.
I have done decals this way but this is a white back 3M product and I believe they are supposed to go on dry.
Can anyone verify this?
Old 02-06-2013, 08:48 AM   #4
Rugged Brown's Avatar
Try this
How to Apply 3M Scotchcal Film | eHow.com
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 02-06-2013, 08:49 AM   #5
jeepman71's Avatar
The link isn't working.
Old 02-06-2013, 08:51 AM   #6
jeepman71's Avatar
The E-How link worked.
Thanks.
Old 02-06-2013, 08:53 AM   #7
Try this.
Terry/Bernadette
Lily the Yorkie
Old 02-06-2013, 09:36 AM   #8
jeepman71's Avatar
Great, thanks for the link.
Old 02-06-2013, 09:52 AM   #9
Graduate Member
RoadTrip's Avatar
Good to know! And great answer - I feel like I know what I'm doing already
--2009 Sunseeker 2860DS (Class C)
- one Hotwife, and two boys under 2(with one on the way!)
2013 - 53 days
2012 - 26 days
RoadTrip is offline   Reply With Quote
Old 02-06-2013, 10:05 AM   #10
Witch Doctor's Avatar
This is the correct way I had decals replaced on my unit. once you have it in place spay a little more water on the felt part and it will pull off very gently. also use blue tape in areas to help hold it in place..
Coachmen M/H
Concord
2018 / 300 DSC
