Old 09-13-2011, 01:33 PM   #1
Diamond plate
I have a mini-lite 1809 and I was thinking about diamond plate on the front of the trailer for a rock guard. Has anybody tried this? Any suggestions on how to attach to the fiberglass? Thanks
smack is offline   Reply With Quote
Old 09-13-2011, 01:44 PM   #2
TURBS's Avatar
Doing the same thing. Going to glue it an screw it.
1/16 inch thick thread plate
Old 09-13-2011, 03:52 PM   #3
Are you using construction adhesive?
Old 09-13-2011, 06:44 PM   #4
Redheaded blue tick's Avatar
to be able to remove the plate later if you need to, i would use a silicone adhesive, wipe down the area with a 90% alcohol, make sure you seal the edges and fill screw holes with the sealant
Pat and Angela Malerk
2017 Dodge 3500 Diesel Dually 4x4 towing
2011 Rockwood Windjammer 3008W
Hitch: 1200 Equalizer
Redheaded blue tick is offline   Reply With Quote
Old 09-13-2011, 07:00 PM   #5
TURBS's Avatar
clear silicone is what i am using
Old 09-13-2011, 07:57 PM   #6
Do you screw into the fiberglass or is there some structure under the fiberglass that you screw into?
Old 09-13-2011, 08:16 PM   #7
TURBS's Avatar
i am screwing mostly into the frame structure behind it . a lot of measurements to get it all figured out .
i am also screwing and nutting to the fiberglass if needed to make sure its all secure .
Old 09-14-2011, 08:48 AM   #8
Head Rambler
I used butyl tape every where the screws were going and screwed it to the aluminum frame with stainless screws. I also used a piece of aluminum flat bar as a backer on top of the diamond plate to spread the screw pressure out.
Gotta go campin!
Old 09-15-2011, 06:42 AM   #9
What is the best way to determine were the underlying structure is to screw into?
Old 09-15-2011, 07:26 AM   #10
TURBS's Avatar
I have a 5er so I just opened the front access cubby door and started measuring from door to structure from the inside and transferring that dimension on the outside
