Old 07-13-2016, 04:31 PM   #1
Did not dewinterize
I had no need to drain the antifreeze from my A122. Will it be good for next winter (2016-2017)?
Thank you
JC Slugger is offline   Reply With Quote
Old 07-13-2016, 04:36 PM   #2
WFD
absolutely.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 09-08-2016, 06:05 PM   #3
Do I need to fully winterize
Hello:
I winterized our A122 in October 2015. In 2016 I did not use the water heater or water tank or pump. I only connected to city water. When we got the camper cleaned up after our last trip of this year, I opened the faucets and then used a winterizing hand pump kit to winterize the city water connection. Will my A122 be ok for the upcoming Wisconsin winter?
Thank you
JC Slugger
Old 09-08-2016, 06:15 PM   #4
Ford Idaho's Avatar
Did you pull the caps or open the valves for the low point drain?
I would just drop some antifreeze in the P traps and toilet bowl and call it good after that.
Old 09-08-2016, 07:02 PM   #5
Low point drains
Does anyone know if the A122 has low point drains other than on the freshwater tank?
Thank you
JC Slugger
winter, winterize
