Old 08-26-2015, 01:08 PM   #11
Vince and Charlette's Avatar
FR Georgetown operators manual says 1/4 cup (non-scented) per 1 gal water. Pour into tank. I poured solution into hose using funnel. Then hooked up hose to potable water source, filled tank as per manual and ran all outlets until smell chlorine. "Leave sit for at least 3 hours, then drain tank"; partially refill tank and flush out lines. Then drain the tank. So says FR.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 08-26-2015, 01:35 PM   #12
We own an Aliner liner and the manual suggests using(point) . 13 times the number of gallons of fresh water capacity for the number of ounces of bleach to sanitize the tank. Add the bleach with water, use a funnel, etc. Run the pump to get bleach water throughout the system. Leave in 4 hours., then drain, fill with water and drain again. Make sure to run the pump again until no bleach smell. Our water has no taste or smell. I have always used bleach to sanitize potable water container, when camping and hiking. I think it works.
kjamesro is offline   Reply With Quote
Old 08-26-2015, 01:43 PM   #13
Flybob's Avatar
Originally Posted by 05CrewDually View Post
For the rest of the season there is no worries because I only fill off my house which is city water containing chlorine already so it stays clean.
Not always true. The chlorine in the city water rapidly evaporates out and will have little effect after a while especially if stored in hot weather. (Same reason you need to add chlorine to pool or hot tub daily). To see for yourself. Fill a glass with city water. Cover lightly and place in warm room or garage for two weeks. Most likely something you want to drink.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-26-2015, 02:25 PM   #14
2007 WildCat 32QBBS
05CrewDually's Avatar
Sorry I should of mentioned but my coach doesn't sit, especially 2 weeks. Never had a problem but I hear what you're saying.
05CrewDually is offline   Reply With Quote
Old 08-26-2015, 06:50 PM   #15
Send a message via Yahoo to Magee
Once, in 2 or 3 years, on RV park water, my hot water got nasty smelling. I put Clorox bleach (not too much) in water tank and pumped it through system, & let set a few hours. Opened faucet (water heater was off) and used water pump to empty tank and water heater. Hooked back up to RV park water and never had any more problem. That was BEFORE all chlorine bleaches were "concentrated", which seems to make foam. Perhaps you could find some non-concentrated bleach at a dollar store or some such.
Magee is offline   Reply With Quote
Old 08-28-2015, 05:34 PM   #16
etothepii's Avatar
I have a blue fresh water tank I sometimes use to add water to the tank at state parks when I need to. So what I do each spring is fill it, add a cup of bleach, pour it into the water tank, then fill it up. I figure that helps sanitize that blue tank each spring. I pump water throughout the plumbing system, no water heater. It sits over night. Then I drain it.
2014 Rockwood 2306
Fastway E2 equalizing hitch
Prodigy P2 brake controller
2011 Ford F150 Ecoboost, Supercab
etothepii is offline   Reply With Quote
Old 08-29-2015, 09:38 PM   #17
Too much chlorine
EPA guidelines for disinfecting water are 1 teaspoon of 8.25% bleach per 16 gallons of water. There are 48 teaspoons in a cup. Unless there has been black water in your tank, you don't need much clorox. City water usually has a chlorine residual, so when you fill your tank with fresh water the chlorine stays for a while and kills bacteria in the tank. When I bought my used trailer, I used a lot of chlorine, because I didn't know what was in the tank. It took me 4 tanks of water to get rid of the taste. If you're staying a long time, you could add a teaspoon or two of bleach and it won't affect the taste too much.
Emergency Disinfection of Drinking Water | Emergency Preparedness | US EPA
mnoland30 is offline   Reply With Quote
Old 08-29-2015, 10:16 PM   #18
Telstar's Avatar
To sanitize fresh water tank prior to long term storage:
  • Remove water filter
  • Activate water heater bypass
  • Drain water heater
  • Mix 1 tsp of bleach (plane, no additives) for each gallon of water. 70 gal = 70 tsp = 11 1/2 oz (1 1/2 cups) Mix with water in a gallon jug
  • Add mix to fresh water tank then fill with water
  • Rock rear of trailer to complete mixing process or drive a few miles
  • Run treated water through all faucets and toilet until you smell bleach
Pre-trip :
  • Drain and fill fresh water tank twice
  • Connect house water to trailer
  • Run fresh water through all faucets and toilet
  • Shut off house water and turn on pump
  • Run cold water through one faucet to clear tube from fresh water tank
  • Reinstall water filter cartridge
  • Deactivate water heater bypass
  • Open vent at top of water heater to facilitate filling then close
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2005 F-350 6.0 psd CC SRW
PullRite Super 5th
Telstar is offline   Reply With Quote
fresh water, tank, water, water tank
