Old 08-25-2015, 11:14 PM   #1
Disinfecting Fresh Water Tank
We just purchased a used travel trailer, and I would like to disenfect the fresh water tank. I have read that you use bleach to do this. I've never done this before. How do you recommend getting the bleach into the tank? Also I have read mixed reviews on whether or not to let the bleach water into the hot water tank. Any tips will be greatly appreciated!
roxie1824 is offline   Reply With Quote
Old 08-25-2015, 11:31 PM   #2
One method I have read about on this site to get the bleach in the tank is to use a funnel and pour a few ounces of bleach in to the end of the water hose you are going to use to fill your tank. Just keep the hose high so it won't run out. Connect it to your trailer and when you turn on the water it will be forced into your fresh water tank. Don't use to much bleach!
As far a hot water goes, you are not drinking it plus it already get sterilized by heat. Just don't run the hot water until you are finished sterilizing the fresh water tank and no bleach should get into it.
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 08-25-2015, 11:33 PM   #3
Wobbles's Avatar
I too am interested in the proper treatment of the FW tank.
It seems like every time I return from a trip is has enough water (any may be an issue) that I worry about it getting funky between trips.
How do others handle this?
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is online now   Reply With Quote
Old 08-25-2015, 11:51 PM   #4
2007 WildCat 32QBBS
05CrewDually's Avatar
At the start of the season I dump a cup of bleach in the holding tank fill using a funnel. Then I fill the tank about 3/4. Then towing it around to my driveway it sloshes around. I activate the water pump and turn on the kitchen cold water faucet, bath cold water and run the toilet until I smell bleach. Since its the start of the season the filter is removed from winterizing. At the end of the day I open the drain and drain the tank empty. Then I rinse by hooking up my home city water.
For the rest of the season there is no worries because I only fill off my house which is city water containing chlorine already so it stays clean.
05CrewDually is offline   Reply With Quote
Old 08-25-2015, 11:51 PM   #5
Just a member
kandl's Avatar
FWT sanitization a la FR:
Forest River RV Online Owners Manuals
Navigate from FR Travel Trailer English..., click on Plumbing then Sanitization.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 08-25-2015, 11:54 PM   #6
The part about the (Hot water gets sterilized by heating) is only true by (Being Over 212 Deg.) this is not the case in a RV Water Heater! Youroo!!
Old 08-26-2015, 11:46 AM   #7
RVPP's Avatar
A caution, bleach and stainless steel, your hot water tank, don't get along.
There are other ways to skin that cat.
RVPP is offline   Reply With Quote
Old 08-26-2015, 11:58 AM   #8
Georgia Frog Rally 2018
aceinspp's Avatar
X2 Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 08-26-2015, 12:19 PM   #9
Telstar's Avatar
For the best advice and step by step videos go to RVgeeks on YouTube.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2005 F-350 6.0 psd CC SRW
PullRite Super 5th
Telstar is offline   Reply With Quote
Old 08-26-2015, 12:50 PM   #10
BooBoo23's Avatar
Don't put the bleach in first. Put some water in the tank, then some bleach, and then add the rest of the water. Do a Google search on the subject so you find out the right amount of bleach per gallon of water. Lots of info on the issue. To little won't work and to much will leave the bleach smell in the water for a long time.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is offline   Reply With Quote
fresh water, tank, water, water tank
