Old 03-29-2018, 06:25 PM   #1
miketrav03's Avatar
Distance between tires
I want to put a wheel lock between my tires on a 2018 Rockwood mini lite 2509s and they come in small and large. I dont know what size to get. Can someone help me out on this please.
miketrav03 is offline   Reply With Quote
Old 03-29-2018, 06:33 PM   #2
what style lock? what manufacture? whats the difference between small and large? need more info for any help.
Kimber45 is offline   Reply With Quote
Old 03-29-2018, 06:35 PM   #3
miketrav03's Avatar
Camco RV Wheel Stop- Stabililizes Your Trailer by Securing Tandem Tires to Prevent Movement While Parked- 26" to 30" Tires- Small*
Old 03-29-2018, 06:36 PM   #4
miketrav03's Avatar
They are the small
Old 03-29-2018, 07:08 PM   #5
Chief T's Avatar
Should work, got these from Amazon.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Safe and happy travels.
2012 GMC Sierra 1500 SLT Z71 6.2l aka "Luci"
2020 Grand Design Imagine XLS 22 MLE aka "Desi"
Past: 2017 Prime Time Tracer Air 206
Days camped 2021: 19
Days camped 2020: 18
Days camped 2019: 17
Chief T is offline   Reply With Quote
Old 03-29-2018, 07:09 PM   #6
miketrav03's Avatar
So I wouldnt need the large?
Old 03-29-2018, 07:13 PM   #7
Chief T's Avatar
I looked online and your tire spacing is what I have. These are designed for tires with spacing of 1-1/2" to 3-1/2"
All the best.
Old 03-29-2018, 07:13 PM   #8
miketrav03's Avatar
Where did you find the tire space at?
Old 03-29-2018, 07:15 PM   #9
Chief T's Avatar
Also, after you're set up and put these on, retighten a bit later as the tires will cool off and shrink a bit.
Old 03-29-2018, 07:15 PM   #10
Chief T's Avatar
Measure the distance between the two rear tires.
Old 03-29-2018, 07:16 PM   #11
miketrav03's Avatar
I mean where online did you find the distance of the tires
Old 03-29-2018, 07:18 PM   #12
Chief T's Avatar
I looked at pix online and they are close together.
Old 03-29-2018, 07:20 PM   #13
Measure the distance between your tires at the closest point. The Camco Wheel Stops give a range that each size (small or large) will fit. I think it’s on Camco’s website.
I’m gonna guess that small will work on your tt, but that’s a wag. The small worked on our 2703WS.
The specs are on Amazon also.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
andymil is offline   Reply With Quote
Old 03-29-2018, 09:03 PM   #14
I used BAL chocks for years and they work very well. See video here:
BAL - Innovative Products for the RV Industry
john a v is offline   Reply With Quote
Old 03-29-2018, 09:33 PM   #15
My 2016 Mini Lite 2503S tires are 2-1/2" apart. I use the standard BAL X-chocks. They can go from 1-3/8" up to 10".
The extended version will go up to 17".
http://norcoind.com/bal/products/con...s/chocks.shtml
2011 Traverse LT, 3.6L, FWD
Old 03-29-2018, 11:15 PM   #16
This seems to be the same link I posted above. Good little video there .... I learned something, although I'm not sure I will follow it to the letter.
They say to install the chocks AFTER unhooking and remove them BEFORE hooking up. I have never done that. I put them on Immediately on arrival then UN-hook ..... and take them off AfTER hooking up. I see the reasoning, but then you have to (or certainly should) use some sort of alternative chock in the interim.
I do check the tightness after the tires have cooled and from time to time while camped.
Never had a problem.
One note of caution !!!!!! Do not forget to remove the BAL Chocks before moving the trailer. You could blow your tires!!!!
Cheers,
John
tire
