Old 03-04-2011, 10:50 PM   #1
Do an AC power outlets work off battery?
Hi Guys,
I'm new to the RV world and am picking up a 2604 next week in Ohio. My question is: Do any of the AC outlets work when you are running off the battery? I know it has power converter so I'm thinking that they might. I just want to use them to charge my laptop and phones. I will be driving it from Ohio to Texas hoping that it doesn't snow and dry camping (rest stops) during the evenings. So at night I want to use my laptop and keep my battery charged. If they don't work then I will buy a converter for the truck and charge it during the day; but don't want to waste my money on a converter if I don't need to. Also is it alright to drive with a full tank of fresh water? I'll need it to take showers after a long day of driving? Any other suggestions for the trip?
thull87814 is offline   Reply With Quote
Old 03-04-2011, 11:02 PM   #2
Send a message via Skype™ to scubieman
Chances are not. Most RV'S only have chargers to charge battery. You will need a power invertor to be able to power up 110V devices. That takes 12v to 110v. Being you just want laptop and phones you can just get a 150 watt power invertor. I recommed 400 watt just in case. Usually they are about 30 to 50 bucks when said and done.
It is fine to drive with a full tank of water. It is just extra weight you have to pull. 8.33 pounds per gallon worth of weight. I would say pull some just in case you want to use some water for bathroom break or cook a quick meal. Take the rv out and dry camp for a weekend. Then you will truley know what you need and what you dont. Make a list , do much much research like you started. o BTW welcome to the forum
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 03-04-2011, 11:50 PM   #3
Moderators' Assistant
bikendan's Avatar
no, the AC outlets only work if you have shore power or a generator.
your trailer will have a CONVERTER, not an INVERTER.
the converter will take AC and turn it into DC, for the lights and other 12v items. it will also use the shore power to recharge the batteries.
an inverter takes 12v battery power and turns it into 110v AC power.
as far as carrying water, unless you're near your tow max, should be no problem.
Old 03-05-2011, 12:11 AM   #4
thanks for advice
I plan to do just that when I get the RV home. Going to set it up at the lake just a mile from the home. First I'll do full hook up for a few days then I'll then I'll go dry. That should allow me to get it set up for some trips. Plan to take it to some national parks next year and will most likely go dry. I'm going to go ahead and buy an inverter for the truck and will go ahead and fill the fresh water tank. Will need to take some quick showers at night. Thanks for the advice!
Old 03-05-2011, 07:36 AM   #5
Herk7769's Avatar
I am sure you meant buy and inverter for the camper; not the truck.
The inverter will need to be connected to the house battery in the camper; not the starting battery in the truck.
Starting batteries are designed to give up all their charge in one or two blasts of power to start your truck. Thin plates with lots of surface area. They discharge and recharge quickly and at high amps.
House batteries are designed to give up their charge at a much slower rate; but over a LONG time. Thick honeycomb plates that release and take power much more slowly.
Look for a 1000-1500 watt inverter. Anything more is a waste since you will destroy your house battery trying to pull that many amps out of your house battery.
Watch your wire sizes. Make SURE your 12 Volt DC cables are big enough to handle the current load of the inverter you choose. You could easily pull 200 amps continuously through a large one.
Most house batteries being shipped now are 75 amp hour ones. That means that at 20 amps draw; they will last 20 hours to dead. For maximum life you should never use more than 30 percent of the available amps without charging it back up. Most deep discharge batteries are only designed to go from full to empty (full cycles) about 200 times before they are ruined.
HAM CALLSIGN - KC3FFW
Old 03-05-2011, 08:17 AM   #6
Actually I was thinking I would get an inverter for the truck. I thought that I would charge the computer while I'm driving, but that way I would only have a few hours of use from the computer battery. Your way I would be able to use it for a longer period, but I don't want to risk running the camper battery down. I would think that it should not be a problem if I hit the road the next day. A days worth of driving should get it charged back up. I'm still a bit confused about the amperage on the inverter. Why would I want more than a 400 amp inverter as scubieman recommended?
Old 03-05-2011, 09:07 AM   #7
Herk7769's Avatar
If all you want out of your inverter is to charge your cell phone and computer, a 400 watt inverter should be fine. I have one of those in the truck just for that purpose. A 400 watt inverter will deliver 3.25 amps or so at 120 volts. The iPad uses about 0.5 amps to power the AC Charger when charging. Our Gateway Laptop needs 1.6 amps to use the AC power pack.
Make SURE the 12 volt outlet you select is the one the cigar lighter plugs into and not a lower amperage "accessory" outlet. The accessory outlets in some vehicles are very limited on their amps. You might even consider a hardwire run from the battery with an inline fuse.
For the camper; something more substantial might be in order if you or your spouse wants to watch 120 AC TV while you charge the computer and phones.
Old 03-05-2011, 09:12 AM   #8
Glenn5995's Avatar
Originally Posted by herk7769 View Post
...Most house batteries being shipped now are 75 amp hour ones. That means that at 20 amps draw; they will last 20 hours to dead...
Lou, I don't believe you have that quite right. A 20 hour Amp Hour Rating is the amps the battery can supply at a continuous rate for a 20 hour period (the battery being dead - not a good thing). So a 75 AH battery can deliver a constant 3.75 amps for 20 hours. In my case, I have a 260 AH rating so they can provide a constant 13 amps for 20 hours.
Reserve capacity is how long a battery will last at a particular amp usage. In my case I have a 450 min capacity @ 25 amps, so drawing 25 amps they would last 450 minutes. Again this is to complete discharge which is not a good thing.
Glenn & Beth (Dad & Mom)
David & Audra (12 year old twins)
Glenn5995 is offline   Reply With Quote
Old 03-05-2011, 09:21 AM   #9
Herk7769's Avatar
Additionally you seem confused by watts and amps. Watts is power and amps are current.
Watts can be calculated by multiplying volts times amps.
Our Gateway power supply requires 1.6 amps at 120 volts AC to charge the battery in the laptop. 120x1.6 = about 200 watts just for the laptop.
Add the iPad AC power supply requires .45 amps at 120 volts to charge it.
120x 0.45 = about 55 watts.
Old 03-05-2011, 09:27 AM   #10
Herk7769's Avatar
Thanks Glenn, you are right; of course. Thanks for catching my "mis-spoke" It even happens to politicians I heard. It is early and I need more coffee.
Your clarification makes the case for a larger bank when boondocking on inverter even stronger.
battery
