Old 04-15-2016, 01:37 PM   #11
B and B's Avatar
If you are running digital input, i tried it was all full of noise. The subwoofer would be rerouted as per 5.1 standard means only content deemed sub capable by surround standards would go there to be heard. They assume with most system you have some bass response down to 120 hz in the main Left and Right speakers. In my case the ceiling mounted L C R and SL SR are all the same and likely have poor Lo Frequency response. I run RCA in and use the Heavy or Rock setting on EQ to get some low end.
With my system B is Bedroom and C is outside on the 2 inch drivers in weatherproof cabinets.
Old 04-15-2016, 03:51 PM   #12
camper007's Avatar
Mine is in the ceiling.
camper007 is offline   Reply With Quote
Old 04-15-2016, 04:54 PM   #13
raytwntrvlr's Avatar
Mine is under one of the dinette benches. I discovered it while checking out my furnace. Like many TT things, I was able to improve on the installation with not too much effort. Sounds great now.
2015 Flagstaff Super V 26VFKSS Emerald
raytwntrvlr is offline   Reply With Quote
Old 04-16-2016, 12:29 AM   #14
RangeMaggotBob's Avatar
Originally Posted by bob caldwell View Post
Turn the sound up and add lots of bass....you'll find it!
Good idea
Why didn't I think of that?!? Will try this first.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2000i generators
RangeMaggotBob is offline   Reply With Quote
Old 04-16-2016, 12:30 AM   #15
Originally Posted by slide5r4fun View Post
It's more than likely behind the risers of your stairs. There should be an access panel in your basement that you can remove to check and see. Mine is next to impossible to reach through the basement due to framing but I can see it. Recently, it quit working so I pulled back the carpet from the stair riser and found a wire had come loose. Re-attached and all is good.
I will try this if the first one doesn't work.
Old 04-16-2016, 08:23 AM   #16
Wolverine 1945's Avatar
Originally Posted by tdst51 View Post
My system says 3.1, but I'll be darned if I can find a subwoofer. Anybody have a clue? Thank you in advance.
In our 2013 Sunseeker 2500TS,,, it was in the outside compartment in the Dinning Room Slide,,, It is now in the basement of our home,,, did not need that thumping sound !!!
Wolverine 1945 is offline   Reply With Quote
Old 04-16-2016, 08:43 AM   #17
Witch Doctor's Avatar
I have the same unit, never could here it, I had the factory at Goshen show me where it was at, it was behind the fireplace no sound access at all. I cut in two 5x8" holes in the sides and just covered them with a speaker cover. Still really it was waste of time. But that is where we found it on a 8289WS 2012 model.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 04-16-2016, 08:22 PM   #18
Thanks everybody. At least now I have a few places to check. I will reply on this same thread if and when I find it...
Old 07-16-2016, 05:22 PM   #19
Pockets
Mine is in the wall behind the home theatre box and the bedroom wall. How did I found out? I took the Phoenix box out of the wall to make sure the antennae was connected and noticed a box sitting between the walls on the floor. Wondering what it was for a bit til I realized it was the subwoofer. All's it did was rattle the walls anyways. Overrated.
Bob & Kelley
2015 Flagstaff 26RBSS
2014 FORD F-150 Supercrew 4x4
3.5L Ecoboost, 3:73 axle, Max Tow Pkg
2015(36 nights) 2016(74 nights) 2017(174)
Pockets is offline   Reply With Quote
Old 07-16-2016, 05:35 PM   #20
well I guess he never found it, didn't get back to us. would be nice to let people know, after we took the time to help him out, or let us know they didn't put one in....
