04-15-2016, 01:06 AM
Do I even have a subwoofer?!?
My system says 3.1, but I'll be darned if I can find a subwoofer. Anybody have a clue? Thank you in advance.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2200i generators
04-15-2016, 01:43 AM
Mine in my camber is down behind the fireplace.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
04-15-2016, 05:20 AM
Toy-aholic
mine too
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
04-15-2016, 05:55 AM
mine is behind a dummy cabinet door below the TV and it doesn't work anyway! imagine that!
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
04-15-2016, 05:59 AM
Found mine under my dinette bench...nicely covered in saw dust. (Enhances County music)
Linda
04-15-2016, 06:14 AM
It's more than likely behind the risers of your stairs. There should be an access panel in your basement that you can remove to check and see. Mine is next to impossible to reach through the basement due to framing but I can see it. Recently, it quit working so I pulled back the carpet from the stair riser and found a wire had come loose. Re-attached and all is good.
Kevin & Janine
2019 F350 Lariat DRW
2020 Jayco Pinnacle 36KPTS
04-15-2016, 11:46 AM
Left Coast
Turn the sound up and add lots of bass....you'll find it!
04-15-2016, 11:54 AM
Mine was supposed to be in the cabinet under the tv but it's not. Lol
Must be in someone's car at the plant.
04-15-2016, 12:26 PM
Turn on all speakers (A, B & C). Some subs are on a different switch than the mains depending on which amp you have.
"Lurch" = Georgetown 2011 330TS
Toad = Jeep 2016 Cherokee
Pilot = Bob
First Mate = Xiangbing
Crew = Radar, NiuNiu & NaNa
04-15-2016, 12:35 PM
Mine is under the kitchen sink in the island.
2013 GMC Savana 2500 FBI Edition
2015 Rockwood 8327SS stuffed with 5 kids!
SE Michigan
Nights camped 2014: 48
04-15-2016, 12:37 PM
If you are running digital input, i tried it was all full of noise. The subwoofer would be rerouted as per 5.1 standard means only content deemed sub capable by surround standards would go there to be heard. They assume with most system you have some bass response down to 120 hz in the main Left and Right speakers. In my case the ceiling mounted L C R and SL SR are all the same and likely have poor Lo Frequency response. I run RCA in and use the Heavy or Rock setting on EQ to get some low end.
With my system B is Bedroom and C is outside on the 2 inch drivers in weatherproof cabinets.
B and B
04-15-2016, 02:51 PM
Mine is in the ceiling.
04-15-2016, 03:54 PM
Senior Senior Member
Mine is under one of the dinette benches. I discovered it while checking out my furnace. Like many TT things, I was able to improve on the installation with not too much effort. Sounds great now.
2015 Flagstaff Super V 26VFKSS Emerald... SOLD
Now camping with a new SOB Winnebago pulled by a 2021 Ford Ranger.
04-15-2016, 11:29 PM
Good idea
Why didn't I think of that?!? Will try this first.
04-15-2016, 11:30 PM
I will try this if the first one doesn't work.
04-16-2016, 07:23 AM
In our 2013 Sunseeker 2500TS,,, it was in the outside compartment in the Dinning Room Slide,,, It is now in the basement of our home,,, did not need that thumping sound !!!
04-16-2016, 07:43 AM
I have the same unit, never could here it, I had the factory at Goshen show me where it was at, it was behind the fireplace no sound access at all. I cut in two 5x8" holes in the sides and just covered them with a speaker cover. Still really it was waste of time. But that is where we found it on a 8289WS 2012 model.
Coachmen M/H
Concord
2018 / 300 DSC
04-16-2016, 07:22 PM
Thanks everybody. At least now I have a few places to check. I will reply on this same thread if and when I find it...
07-16-2016, 04:22 PM
Pockets
Mine is in the wall behind the home theatre box and the bedroom wall. How did I found out? I took the Phoenix box out of the wall to make sure the antennae was connected and noticed a box sitting between the walls on the floor. Wondering what it was for a bit til I realized it was the subwoofer. All's it did was rattle the walls anyways. Overrated.
Bob & Kelley
2015 Flagstaff 26RBSS
2014 FORD F-150 Supercrew XTR 4x4
3.5L Ecoboost, 3:73 axle, Max Tow Pkg 2015(36 nights) 2016(74 nights) 2017(174 nights) 2018(157 nights) 2019(79 nights) 2020(108 nights)
07-16-2016, 04:35 PM
well I guess he never found it, didn't get back to us. would be nice to let people know, after we took the time to help him out, or let us know they didn't put one in....
Coachmen M/H
Concord
2018 / 300 DSC
