Old 05-31-2015, 11:04 AM   #11
Originally Posted by Tracer215AIR View Post
I am unaware of the manufacture of the bars and I can only go by what a fellow camper (who has more experience) told me in regards to them snapping. I am only assume that any system can fail and/or provide years of dependable service and sarcasm.
Tracer did you also Read Post# (9)? Also the System that you have uses (BARs) as well! Youroo!!
youroo is online now   Reply With Quote
Old 05-31-2015, 01:15 PM   #12
Yes to WD and SC
Sway control is essential. Can save the day!
Harkerr is offline   Reply With Quote
Old 05-31-2015, 01:38 PM   #13
If you are looking for an equalizing and best sway control. I have used several. The best by far is the Andersen hitch. It is an equalizing, anti bounce, and sway control. Easy to use and works perfect. I have a Wildwood 38ft with three slides and it is a dream to tow with this hitch. Send me questions I would be glad to answer them, John
jpbenitz is offline   Reply With Quote
Old 05-31-2015, 01:49 PM   #14
Originally Posted by Evergreen49 View Post
The Rockwood 2109s is about 4,000 Dry weight and about 500 hitch weight. I will be towing it with a 2015 Ford F150 ecoboost. Do I need a 1,000/10,000 E4 hitch? And does it compicate the backing up and parking the TT?
Thanks, Evergreen49
I brought my trailer home from a dealer on a windy bumpy road and it was swaying all over. That night I went to Harbor freight and bought the WD and installed the next day. A couple days later I took the trailer back to the dealer to have him check something for me. I took the same roads and what a difference! No swaying rocking or rolling! Towed like a dream!
As for how it handles you won't have any problems with it. When you backup the trailer use the same common sense as you would without the WD. You shouldn't have any problems at all.
I don't have these problems anymore since I got my fifth wheel but I would never toe another trailer without a weight distribution hitch if I had a choice.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 05-31-2015, 06:58 PM   #15
I have been through three iterations of hitches and sway control. I just installed a new Equalizer and find it to the be best and much, much better than the Reese duo cam. One thing I know for sure is that you must set it up exactly as specified in the instructions. You must load your trailer AND tow vehicle with the things you plan to normally carry, including propane tanks, water, food, clothing, etc. There are measurements you must take to set the height of the ball and the tow vehicle wheel well heights before and after setting the bars in place that you will use to determine the amount of tension on the bars. The instructions are clear and you do not have to be a professional
mechanic to install the Equalizer. One of the major problems that folks tell me about is that lots of dealers do not load the TT or Tow Vehicle when they are installing the hitch and this leads to a set-up that requires retuning in order for maximum performance.
magpi26 is offline   Reply With Quote
Old 06-02-2015, 07:02 AM   #16
Ditto. Towing a 34ft Salem Hemi with Andersen. This is my 4th TT. Andersen is by far the best WDH I've ever had. Not knocking other brands, just think Andersen is lightest, easy to set up and works. Eliminates bounce and sway. was like towing my 37ft 5er.
George Scott
2015 Salem Hemisphere Lite 272RLIS/ Prodigy P3
2006 Heartland BH 3400/Summer Home
2007 Dodge 2500 CDT QCSB/Blue Ox Sway Pro 1500lb WDH, Maxxis 8008 225 x 75 x15 LR E tires/J T Strongarms
Scotty is offline   Reply With Quote
Old 06-02-2015, 07:20 AM   #17
Start here:
Ford Towing Guides | The Official Site of Ford Vehicles | Ford.com
That will give you the numbers from Ford as to requirements.
I always advocate for the sway control now. Realize it is a personal choice however.
Underthedog is offline   Reply With Quote
Old 06-02-2015, 07:21 AM   #18
Boss Ox & Drovergirl
oxcamper's Avatar
1. I wouldn't tow without one.
2. I did find, depending on the site I have to back into, it is easier to remove the bars prior to backing in the site because you can jacknife the trailer a lot further if you have to. It is easier to remove them on the straight and level and the manuvering is easier without the,=m
3. In normal situations, backing and manuvering witht he WDH is not an issue.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 06-15-2015, 09:43 AM   #19
wpgman19's Avatar
Originally Posted by youroo View Post
The (Bars) are made to be used within a (Weight Range) that is why they are made (400# thru 1400#) now if you have a 1200# unit and use (500# Bars) they WILL/CAN Bend and Break!! Youroo!! That is WHY people need to Know their REAL Down the ROAD T/W! NOT I THINK my Trailer weights ???? and I think we carry ???# inside!
If I upgrade my bars from 1000# to 1200# or even 1400#, will it also reduce the bounce I get on the highway?
2014 Rockwood 8310SS Diamond
2014 F-150 Super Cab Ecoboost w/Max Tow
Nights Glamped - 2015 - 24
Nights Glamped - 2016 - 4
wpgman19 is offline   Reply With Quote
Old 06-15-2015, 08:02 PM   #20
The answer to that question depends on what your real TW is loaded. However if you have the trailer listed, even the unloaded advertised hitch weight would require a 1000# rated hitch.
madmaxmutt is offline   Reply With Quote
sway
