Old 06-17-2015, 09:24 AM   #31
wpgman19's Avatar
Originally Posted by madmaxmutt View Post
There is no difference AS LONG AS the hitch weight is properly accounted for, but for simplicity just let the bars dangle if the scale master lets you.
And there are many that would disagree that the Equal-I-zer "is the best unit on the market", but it is a solid contender. Since you own it, I would not get a different one if it were me. I would verify the bars meet your requirement, though.
Actually, I don't have the Equal-I-zer setup - only the standard bars and chain with a sway bar. I am thinking of switching to the EQ 4-point. Sounds like that will assist greatly with side-to-side sway as well as bounce.
2014 Rockwood 8310SS Diamond
2014 F-150 Super Cab Ecoboost w/Max Tow
Nights Glamped - 2015 - 24
Nights Glamped - 2016 - 4
wpgman19 is offline   Reply With Quote
Old 06-17-2015, 09:37 AM   #32
Sorry, I assumed because this thread was focused on an E4 that is what we were discussing. Yes, an Equal-I-zer will help you. I would also take a look at some of the other new offerings including the Andersen if you are truly in the market to buy something new.
madmaxmutt is offline   Reply With Quote
Old 06-18-2015, 05:59 AM   #33
53flattie's Avatar
Originally Posted by Brewhedd View Post
I bought an Equalizer and set it up according to directions. My front end ended up at the same point as without a trailer. My rear was lifted 2 inches. I contacted Equalizer for their opinion and they told me it sounded like it was good. It was, my towing was improved 100%, hardly any sway at all. It turned my towing experience from stressful to easy. I pull a Rockwood 2702ss weighing 5500 lbs.
I was under the impression that your rear bumper needed to drop 1" or so, in order to have some tongue weight. But maybe I'm wrong.... I'm still getting mine dialed in exactly right - towed three times and each trip gets a little better.
2015 Rockwood 2306
2006 Toyota Tacoma
53flattie is offline   Reply With Quote
Old 06-18-2015, 07:28 AM   #34
Before I got my 5th wheel I used this WDH on my trailer:
10,000 Lb. Capacity Weight-Distributing Hitch System
What a difference it made! A friend then recommended I add this: (added two, one for each side)
Trailer Sway Control Kit
Between the two things I didn't know the trailer was back there! If I were to go back to a TT instead of a 5th wheel (not likely!) I would do this again in a heart beat! Between the two there was no bounce or sway once adjusted properly.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 06-18-2015, 08:22 AM   #35
wpgman19's Avatar
Jim
Very helpful. Thanks Jim.
sway
