Old 08-28-2015, 07:58 PM   #11
MCTroy
Our 3m command hooks have all fallen off when the camper gets hot. Our unit gets to about 100 degrees during the week when we aren't there. All the stick on hooks gave it up.. Going back to small nails but not where we would hit any pipes or wires.
MCTroy is offline   Reply With Quote
Old 08-28-2015, 08:55 PM   #12
Fell off? Did you do all the stuff on the directions? Just curious because I've never had an issue through summer or winter with them.
Sent from my XT907 using Tapatalk
2016 Flagstaff 23LB
howie70 is offline   Reply With Quote
Old 08-28-2015, 10:19 PM   #13
dj3spots's Avatar
Does anyone know what this would be?
I use command hooks to attach pretty much every and any thing to the trailer walls. I even use the strips to hold things to the wall when I'm not sure where I actually want something - that way when I change my mind or we find the item is in an inconvenient place, we move it. I've wasted a lot of command strips and saved the trailer walls. There is also 'permanent' double sided tape that can hold heavier weights than the command strips, I've used it too. And... We've never had them fall off the walls no matter what the temp was or how heavy the item.
dj3spots is offline   Reply With Quote
